Question about Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
I started my PS3 and a screen appeared that said the following: Cannot start. The correct hard disk was not found. What does this mean and how can I fix it?
  • 38 Answers
U will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Posted on Jun 30, 2009
Ps3 slimline says cannot start the correct hard disk was not found
Dear Friend,
Have you consider to replace your hard drive?. That might be a good possibility why your PS3 can not start the way it should. Try that and see what happens.
Good Luck!
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Cannot start -correct hard disc cannot be found!!!! this has suddenly appeared on the ps3
This likely means your hard disk has come loose for some reason. This can happen if the system get's bumped around too much or too hard, or even from rough transport. i.e., the back of a car
All you need to do is open 'er up and push it back into place. Follow the steps found here and you should have no problem getting your unit open safely.
Oct 12, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 screen says " cannot start, the correct hard disk was not found." after turned on. will do nothing else. any ideas?
A long shot but it sounds like your hard drive has basically "switched off". If you have a USB sata hard drive dock I can help but its a bit of a complicated process. You need to remove the hard drive from the PS3 and plug it into the USB sata dock then connect it to your computer. Goto Control Panel -> Administrative Tools -> Computer Management -> Disk Managment. Look in the lower area of the screen that appears for your PS3 drive, probably E:, and look if it says "Not initialized". If it does, right click where it says that then click Initialize Disk. Put it back in your PS3 when it is done and hopefully it will turn back on. You will lose all saved data though as the hard drive will need to be formatted.
Hope this helps
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
As with many of us current and former PS3 owners you need to have your HDD (hard disc drive) replaces. sorry
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
"can not start. correct hard disk not found" screen message
well you may have a bad connection at the SATA port. this happens alot cuz of the heat generated by the CELL CPU (adjacent to the SATA PORT) . either this or your harddrive has failed
Nov 08, 2008 | Sony Playstation 3 (PS3) Console
PS3
This could mean that ur hard drive has failed, this is a a very common problem for hard disc video recorders (PVR).
If you have the confidence, open ur PS3 extract the HD and connect it to a pc to do diagnostics on the HD
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
749 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
