You need to install IJ Scan Uitility and operate it from a connected computer. It appears not to have a direct scan button on the unit.
You can download all the manuals which includes the scanner manual from:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mg_series/pixma_mg2520#BrochuresAndManuals
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
SOURCE: my multifunction Canon Pixma MP830 will not scan.
Will it copy standalone?If it does.
Then it is a software problem or bad cable.
If so you need to uninstall the MP navigator and reinstall without an usb cable attached.Attach a good cable and let Windows install the correct drivers
SOURCE: my canon pixma mp140 won't scan when i press the
This is onlt a try may work
All The Best: Pineworks
SOURCE: need free driver for canon pixma mg 2120
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
