Question about Chaintech VNF3-250 Motherboard
Boot error code 5d on a Chaintech VNF3-250 mobo.
Actually the error on booting reports "post code 5D"
  • 16 Answers
Error Code 5d: Initialize Init Onboard Super IO switch.
Generally caused by a mismatched RAM stick int the MIDDLE RAM slot. Try using a single stick of RAM and boot, make sure you do not put this single stick of RAM in the middle slot, and it should boot right up.
Posted on Jul 03, 2009
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
Canon 5D Mark II error 80
Error Code 80 on the 5D II indicates the a
Malfunction related to the electric control of images has been detected.
Apr 18, 2014 | Canon EOS 5D Mark II Digital Camera
My kenmore washer is stopping constantly and has error codes like 5d, rL, F21 and some other codes. We checked everything the manual says to and it all seems fine. What is the problem?
That 5d is a clue. Too much detergent, the wrong detergent, or detergent in wrong dispenser can cause the 5d which is suds overdose. The F-21 is from banging on the touchpad in frustration!
Keypad error! Take the base panel off and find the tech sheet behind it. The tech sheet will give error codes and what to try. I have an HE washer service manual and some repair photos HERE
Jan 12, 2011 | Kenmore HE2 Plus Front Load Washer
I lost the instruction manual and the code on the machine is 5d. The washer will not drain. This happened once then I did anouther load and it worked fine and the next load I get the same 5d message and it...
The error code is not 5 D it is "S" as in Sierra d. The letters stand for Slow Drain. I had this code and it was fixed in 5 minutes or less. Simply remove the bottom panel from the front of the washer. In the lower right hand corner, there is a tray to catch any items that may slip past the boot on the door seal. Slide this tray out and clean it. You will be amazed at what is in there...money, bobby pins, socks. Reassembe the washer and presto. Fixed.
Aug 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
Error code 5D
5D is actually SD which is suds detection. This could be because you are using non HD detergent.
OR
It happened to me when the discharge hose backed up because the sink into which it was discharging got backed up. It looks like the discharge hose not flowing properly is the most common cause of this error code.;
Nov 02, 2009 | Maytag Washing Machines
What does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Oct 20, 2009 | Washing Machines
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Error code 5d
Dec 21, 2007 | Washing Machines
Chaintech VNF3-250 Motherboard Logo
460 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
