I just replace the rear lift gate with a new windshield glass. Now the interior lift gate light stays on even when the car is parked.
SOURCE: lift gate wont open
OK, this minor collision may have shifted the actual clip and latch assembly. You may have to totally disassemble the latch assembly to release this lift gate.
Any kind of major or minor shifting of the lift gate lock latch assembly can cause misalignment that will jam this delicate precise locking mechanism.
SOURCE: 1994 Jeep Grand cherokee rear lift gate
Well My 94 Jeep Grand Cherokee had the same problem and we had to just cut into the lift gate panel from the inside. It required cutting plastic but with a 94 looks arent everything and a working lift gate was worth it. But then we pealed back this black plastic mat under the panel and lifted up on the release bar(verticle bar that lifts the latch) and once we got it open we adjusted a little clamp that had slipped. Dont adjust it too much or when u lock it it wont lock! But sorry i dont know the name of the parts. But then u can screw the panel back in and it wont look to bad besides some cuts.
SOURCE: liftgate and glass doesn't open
you have to get in behind tailgate interior trim and pull handle lever as this has come off from the actuator,once tailgate is opened remove panel and relocate actuator bar and you might want to cable tie bar in place for the future
SOURCE: liftgate open light stays on all the time
Look for the pin switch on the body where the lift gate is. The switch could be stuck, broken, or corroded. Theres a pin switch on every door to turn on the inside lights, and sometimes they fail. Make sure it is clean, and moves easily. If its stuck, a shot of WD-40 will get it going again. If no matter what you do, you cant get it working properly, replace it.
SOURCE: The
The lift gate latch is at fault the switch contacts in the latch are worn out replace the liftgate latch and your problem is solved
