Cars & Trucks Logo
A
Anonymous Posted on Aug 04, 2014
Does 02 Sentra gxe 1.8 has a diagnostic on its ecm
Tim Hofstetter
Level 3:
Genius:
  • Cars & Trucks Master 1,406 Answers
  • Posted on Aug 04, 2014
Tim Hofstetter
Level 3:
Genius:
Answers
1406
Questions
0
Helped
378518
Points
4295
I don't think I fully understand your question because of grammar, but I'll answer this way. Every car produced (at least for sale in most countries) since 1987 comes equipped with OBDII (On-Board Diagnostics 2), which is capable of giving you any computer error codes when you use an OBDII scan tool (common tool).
Level 3:
  • Cars & Trucks Master 19,187 Answers
Level 3:
Answers
19187
Questions
0
Helped
4341765
Points
82259
That year will have an ODB connection for diagnostics.
1 Related Answer
Anonymous
  • 40 Answers
  • Posted on Aug 01, 2009
SOURCE: Step by step on how to replace front wheel bearing
Raise vehicle, remove wheel, remove brake caliper, remove brake rotor remove steering knuckle by disconnecting the tie rod, ball joint, and strut. press out hub, remove snap rings press out bearing. Reassemble in reverse order.
02 Nissan Sentra GXE 1.8 L. Can anyone tell me whats going on with my car, it keeps doing the description below. I've had it towed twice because it's ZONKed out on me.
there are codes but you have to have the correct scanner and know how to set the ECM switch to get the data link to read out
get it to a specialist service center
Why does it lack spark?
Part 1 -How to Test the Ignition COP Coils (Nissan 1.8L)
troubleshootmyvehicle.com > Nissan > 1.8L
Feb 12, 2013 - What Tools Do I Need to Test the COP Coils. ... coils (most commonly known as the COP ignition coils), on your 1.8L Nissan Sentra is pretty easy. ... When one COP ignition coil fails... that cylinder goes 'dead' due to a lack of Spark and is said to be misfiring. .... 2000, 2001, 2002, 2003, 2004, 2005, 2006 ...
Part 2 -How to Troubleshoot a No Start (Nissan 1.8L)
Jan 17, 2013 - Checking for Spark With a Spark Tester. ... Your 1.8L Nissan will either have a distributor-type ignition system or the more modern COP ... A BAD fuel pumpwill cause your 1.8L Nissan Sentra to Crank but Not Start... since the ... Still, the other method that I've used to test for a lack of fuel... is spraying starting ...
2002 Sentra 1.8, no spark, code 0505... - Nissan Sentra Forum ...
www.b15sentra.net > ... > Technical Discussion
Nov 4, 2008 - 15 posts - ‎3 authors
I have never had a problem with the car before (02 Sentra 1.8/auto), so I had no need to post ... Originally Posted by Black B15 ... Join Date: Jun 2005 ... Can you see if the coilpacks are getting spark & work back from there? how many spark plugs do i need ? - Nissan Sentra ...
Mar 19, 2010
Spark Plug Replacement - 2002 GXE 1.8L - Nissan ...
Oct 12, 2009
1.8s starting problems - Nissan Sentra Forum - B15 ...
Jun 23, 2009
No start on 1.8L 02 GXE - Nissan Sentra Forum - B15 ...
Apr 11, 2009
More results from www.b15sentra.net
Does 02 Sentra gxe 1.8 has a self diagnostic on its ecm/ecu
Not like the models built before 1993 did. You use a code reader or scanner like any other car built after 1996.
Where is ignition control module located for 02 Nissan Sentra gxe 1.8
Located in the distributor (if so equipped). Here is a link on how to do a basic troubleshoot on a no start condition:
How to Troubleshoot No Start Nissan 1 6L 1 8L
2helpful
How to replace heater selector switch
02 sentra vent selector switch not working.
heat does not work either.
2002 nissan sentra gxe
Where can i get free diagrams and manuals for my 02 sentra gxe?
Try the autozone.com website. Go there and register the car information and you'll have access to an online repair manual for the car. Hope this helped and best wishes.
10helpful
Where is ecm located on 2002 nissan senta
The ECM on my 2002 nissan sentra gxe is located on the left side of the firewall if you're standing in front of the car. It's easy to get to and remove, just a few bolts and a harness. The problem is in finding a replacement. Not many of the rebuilders want to deal with this model as they get a lot of returns. Seems Nissan put a foam liner inside the ecm and even if taken out early there were problems as the glue used to hold the foam caused bad problems with the board in the ecm. There was a recall so if your car wasn't fixed you may get an ecm at no cost.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
