Question about RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
    Problem Solver:
  • 7 Answers
Sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Posted on Jul 03, 2009
Testimonial: "I replaced a gasket in the carb. thanks"
Will not start it ran and juat stopped I can put gas in the choke and plug it will run for a few seconds and stop
Ethanol gas wrecks Carburetors and Gas lines. Just for giggles see if the Stone filter in the gas tank broke off the dried out gas line.
Jun 27, 2015 | Weedeater 25cc Gas Blower ()
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Ran well the 1st yr. Added Stabil - would not start this yr. Have put fresh gas in but will not start.
you added stabil but did you run the gas out of the carb? Take the carb apart and klean all with carb cleaner, spray in all holes. Check the plug gap of the new plug while your into the unit anyway the gap should only be 1mm.
Dennis
Nov 06, 2012 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
LEAFBLOWER WON'T START
check fuel lines inside fuel tank, see if will run on a shot of starting fluid e85 gas eats them
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Sep 01, 2012 | Weedeater 2 Speed Gas Blower FL1500LE ()
Need to know how to replace string on weedeater gas blower FL1500LE
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Mar 31, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Won't start after replacing the plug. there is fuel.
get another plug theres a lot of bad small engine plugs on the market that are no good right out of the box! i run into 15 last summer working on weedeaters and chain saws and lawnmowers
Jan 15, 2010 | Homelite 'Yard Broom' Leaf Blower
Carb adjustments for weedeater model gb1 22v
If the blower has ran ok in the past but now not so good I doubt it is the adjustment to the carburetor, I would suspect bad fuel or old fuel first. Empty the blower of gas, pump the primer ball until all of the fuel is pushed through the carb and back to the tank. Add fresh fuel with a premium grade oil (I use gold spectra) and try it again, carburetors typically do not get out of adjustment. I own a 125 BT and have never had any trouble with it other than skunky fuel left over from the previous season.
May 26, 2009 | Husqvarna Backpack Blower 25cc, 140 Mph,...
RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag Logo
907 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
