Question about Panasonic TY-LA1000 Projector Lamp for PT60LC1
Model pt 52 lcx 15 = replaced bulb 6 mts ago now have green line
Panasonic TV - I replaced the bulb 6 months ago, worked fine - later problem started with green,red & blue stars (dots) on the screen. Now I have weard images appearing on the screen. Tried dusting and cleaning the mirrow , but it did not help. Could this be the color wheel going bad? If so how do I replace it?
SOURCE: PT-50DL54 panasonic 50" DLP
This also worked on my Pt-52DL52 Panasonic also by pushing the Blue action button on the remote and the volume down button on the TV. But first wait until the replace bulb warning light is off, then do it.
Posted on Feb 17, 2008
premtech
  • 934 Answers
SOURCE: Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Posted on Mar 02, 2008
SOURCE: Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
stecon3248
  • 57 Answers
SOURCE: Panasonic PT-L701e - colour fault, blacks are blue with lines
Can you connect a computer (vga) signal to this projector? I'd like to know what your "white" computer screen does on the projector....example, Excel spreadsheet....
I am leaning towards these problems, a bad video card...or worse delamination of one of your LCD panels and possible polarizer burn in the optical engine.
Best Regards,
Steve
Posted on Dec 12, 2008
SOURCE: I have a panasonic model
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Posted on May 14, 2009
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
When the TV is turned on the turns off about 10-15 seconds later. The bulb was replaced a few months ago.
There was a recall for this TV's ballast. You need to rebuild the current ballast and may possibly have to order a new lamp.
Jul 05, 2010 | Panasonic PT-50LC13 50" Rear Projection...
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
TV won't turn on - just replaced lamp
I had this same problem. This (panasonic) set is sensitive to the type of bulb used. Don't use a remanufactured one, get a philips/osram or an OEM. If that is what you have, move on to the ballast. Replacing the ballast isn't easy, if you are electronically inclined, you can remove the back panel and the page size aluminum brace, it has two large square cut outs. The shiny silver box under that brace ( maybe 10" x 4") is the ballast. That is typically the next thing that goes out. The bad news is the cheapest I have ever been able to find a replacement was around $350. But again, if you have soldering skills, order a ballast repair kit from ebay ($30) and go to work. If you decide to do that, let me know and I'll email you photos and walk you through it. Once the ballast has been repaired, if it still has the problem, The power supply is bad. At that point take the bulb back out and sell it on ebay or send it back and use a LFH (large F****** hammer) and take out your aggression. Its not worth fixing. The powersupply board is more than the TV is worth. Most of the time this problem is fixed with the ballast. But its a CHORE to get to it and remove it to work on it. I'd be happy to help and I can send vids and pictures, depending on what you'd like to do.
Good Luck.
Jan 11, 2009 | Panasonic PT-43LC14 43" Rear Projection...
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
331 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
