I have a whirlpoll LGR4634EQ2 dryer that isn't getting hot. The drum is turning I have changed the ignitor and that didn't work. Still not heat I still don't see any glow when looking at the iginitor assembly. I also only here one click when I start the dryer on the high heat cycle. What else should I do?
  • courtj Jun 30, 2009
    Thanks.If that doesn't fix the problem what else might it be?
    I don't know if you recevied my reply but if relpacing the hermal fuse still doesn't fix the problem, what would be the next step?
  • 294 Answers
Boss. let me help u..
  • First test is to remove the cover where the plug connects to the dryer and test the two outside terminals for A/C voltage.with a voltage metre..n see if its right as per manual.
  • Also check if the gas is on. Both at the dryer and at the meter or propane tank or supply line from the tank. If there are other gas appliances in the home and those appliances work, the gas is on. If not, the gas is off.
  • Read this: http://fixitnow.com/2003/10/appliance-tip-of-day-ultimate-dryer.htm
  • Run the dryer with the vent completely disconnected and see if the overheating changes.
  • Next place to check is the venting systems exhaust hoods internal flapper. May be stuck closed for some reason. If the flapper is not able to open and close freely, correct the cause of that problem.If there is no front burner access door, remove the bottom back panel and turn the dryer on. Observe the hot surface ignitor. (HSI) The HSI should begin glowing when dryer is turned on and all the control panel selections are set correctly. Meaning not in the "air fluff" or "no heat" selections.
Dryer help info: >Dryer Information + *Fuel Conversion*< Info Contained Here<
N u can Use the reply button to add additional information or ask additional questions on this same appliance.
......................cheerss....hope this old guy deserve a drink!!
Posted on Jun 30, 2009
  • 3,230 Answers
Thermal fuseOn many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
I HAVE A KENMORE DRYER, MODEL # 110.78652700 AND THE BURNER DOES NOT IGNITE. DRUM TURNS BUT NO IGNITION. ANY IDEAS?
check to see if the ignitor is lighting,, if it is,, then you need the coils replaced, on the burner control,, this link shows where they are http://www.applianceblog.com/mainforums/sears-kenmore/17748-kirkland-gas-dryer-no-heat.html if the ignitor isn't glowing,, replace it
Aug 22, 2011 | Dryers
Whirlpol dryer intermittently dryes clothes. dryer p/n LGR8620PWO I do see the glow plug glowing put no flame.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Whirlpool Dryers
I changed the fuse and the dryer was hot at first but isn't getting hot again. What else can I do?
heatman101
Aug 15, 2011 | Dryers
Dryer quit heating
Before ordering any expensive electrical parts a few checks need to be done with an ohm meter. You can get one anywhere electronics are sold. . How to use a meter. If you cannot get a reading on a component then that would be your problem. themobilian_2260.jpg
Any of these components open and you won't have no heat.
If you have a gas dryer the heat is produced by a blast of warm air generated from the gas valve assembly. The assembly consists of an ignitor, a flame sensor, and a pair of solenoid coils. Power is applied to all of these components at once. In order for them solenoids to operate resistance in the circuit must change. To do that the flame sensor must open and kill power to the ignitor. The ignitor is then a thermocouple supplying power to them solenoids and as long as it stays hot it will allow them coils to remain on. If for some reason the gas didn't ignite the ignitor would cool down and shut off the gas valve. That is your built in safety. So what can go wrong?
If the heats works a little then quits then the coils are getting hot and failing with age.
Manuals ,videos, and more HERE
May 01, 2011 | Dryers
GGW9200LW0 whirlpol dryer runs but ther is no heat. It is 8 yrs, old. Waht to do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool GGQ8831L Gas Dryer
It doesnt throw the flame to dry
The typical gas dryer set up: A thermostat is positioned on the blower housing to judge the drum temp. Next to it is a fuse.cd4488c.jpg If the temp exceeds 350F then that fuse melts and kills the heat but the dryer will still run. When that thermostat wants heat it sends 120 volts to the gas assembly. The gas assembly consists of 2 coils a sensor and an ignitor. The coils work on 120 vac but they are tenderfoots. If anything is running on the same circuit with them they don't cooperate. Enter the big bad ignitor and its cousin, the flame sensor. Both these partners in crime work together to coax them coils into opening. How? The sensor ALLOWS power to the ignitor. When the ignitor is glowing hot as 3 yards of C of C hell then the sensor's bi-metal shuts that glow thingy down. This gives them voltage starved coils a chance to get busy. The surge of power energizes them coils and they yank up the gas gates, the raw gas flows out onto that screaming hot glow thingy and BOOM! Houstion we have ignition!!
As the temp rises inside the drum the control thermostat decides enough is enough and kills power to that gas assembly. The drum continues to rock and roll till the temp cools off and then the control thermostat calls for more heat. So what can go wrong? The flame sensor can die and not put power tot hat ignitor. The ignitor can die too. or both can be ok and the coils work a tad and then get hot and quit.
Aug 21, 2009 | Dryers
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Whirlpool Gas Dryer LGR4634EQ2 is not getting hot, I cleaned the vent,I don`t know whats nexts to try?
You may have damaged the glow bar gas ignitor when cleaning the dryer.. it's a ceramic element that gets brittle after it has been used. And if you bang into it with a vacuum hose or tool or whatever while you're cleaning it, it can crack or break....try cycling the dryer and watch the ignitor while it attempt to heat up... if there isn't any glow at all, its the ignitor... it's a simple job to swap it out...
Let me know if that doesn't work...
KEN
May 09, 2009 | Whirlpool Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Jan 03, 2009 | Dryers
Washing Machines Logo
Top Washing Machines Experts
