Dell 1350cnw Laser Printer Logo
A
Anonymous Posted on Aug 04, 2014
My Dell Printer 1350cnw is showing an error message 092-310, how do I rectify this problem?
I have been using my Dell 1350cnw Laser Printer for many years, but just recently I have been getting an error message 092-310, CDT Sensor Dirty - Clean. I no longer have the product manual, and dont know how to get at the Sensor to clean it.
Level 3:
  • Dell Master 19,187 Answers
  • Posted on Oct 06, 2015
Dell Master
Level 3:
Answers
19187
Questions
0
Helped
4344842
Points
82261
Http://www.dell.com/support/article/us/en/19/SLN152111/en
1 Related Answer
Anonymous
  • 34 Answers
  • Posted on Jan 21, 2010
SOURCE: Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
2answers
Message ctd sensor dirty clean 092-310
Anonymous,
You can click the link below and download the online User Guide. The User Guide will provide information on cleaning your CTD Sensor.
Dell 1350cnw Printer
http://dell.to/1EZ8hL2
Thank You
Dell-Jesse L
Dell Social Media and Communities
How do i fix error code 009-654 on a dell 1350cnw
It indicates that your fuser is having issues. Open the top, and release the fuser using the release clip on either side of the fuser. Lift the fuser up a couple of inches then place it back down ensuring that it is well seated. Then secure the release clips to lock it into place. If this does not work, it may indicate that you need a new fuser assembly.
1350cnw poor printing
the fuser unit may be faulty. change out some of the printer consumable parts.
2answers
Paper jam but no paper in printer
Check the paper paths for any stuck papers.Gently remove any stuck papers.
Turn the printer off and on.Problem solved?
Unplug the printer and restart your PC.
Connect again, turn the printer on and print.
Hope this helps.Thanks!
Please rate this answer.
Dear Sirs, during a firmware update, the internet connection failed. Now the firmware seems to bee corrupted. The printer doesn't start anymore. I opened the printer - I shall disconnect and connect...
Then you will need to unistall and install again.This will delete the firmware and the system will be in the previous state.
If you need more help post back!
Thumbs and testimonial are welcome!
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
1helpful
Shows fuser error. What can be done to rectify the
http://img528.imageshack.us/img528/7835/reset.jpg
Try to reset
I think if you want to use a replacement cartridge, you have to disconnect CN5 and short out CN9. This way the toner will always be treated as the initial cartridge.
Thank You For using FIXYA!!
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
