Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Can't turn the tv on with the remote or the button on the tv. Can you help?
  • 3,600 Answers
You need to give the model and serial number of the remote and the tv then install the codes to operate it. here is a web site to find it http://www.mrremotecontrols.com/
Posted on Jun 30, 2009
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
I need the codes for my ge universal remote so it will work my sanyo television
if the remote has a "code" button you can search for the code by using the power button on the remote.make sure the tv is turned on first.now press and hold the "code" button till the light on the remote stays on.now hit the "tv button,the light on the remote should still be on.now keep hittin the power button until the tv turns off (careful not to press the power button again when the tv turns off or you'll lose the code) then hit the enter button ont he remote.hope this helps you out:) good luck
Sep 21, 2010 | Universal Remote Control GE174Universal...
I need to reprogram my jumbo remote to my tv and dont know how or any codes.please help?
I recommend using the auto-search function of your remote to find the codes for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 27, 2009 | Innovage Jumbo Remote Control
I need a code for the jumbo unviersal remote by emerson for a panasonic tv....very old tv...lol
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 22, 2009 | Innovage Jumbo Remote Control
Programming the innovage remote
  1. Turn on your TV.
I hope that helps.
Oct 04, 2009 | Innovage Jumbo Remote Control
Rca remote not programming with tv
I just got the same remote to work.  I did the auto scan method in the instructions.  turn on the tv, hold the tv and power button on the remote down until it stays lit.  Then press the play button, the remote will blink 10 times, press play again and the tv should turn off in a few blinks.  then when the remote finishes blinking, press the reverse button until the tv turns on again, when the tv turns on, press the stop button.  Hope this helps!
Mar 23, 2009 | iLO 2600 Television
Remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 27, 2009 | Samsung Televison & Video
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
Lone99star
Jan 24, 2009 | Televison & Video
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
Lone99star
Jan 21, 2009 | iLO 3200 32 in. LCD Television
Remote problems
This is the preferred method of code searching our technicians use.
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
I hope this helps you and thanks for using Fix Ya.
Dec 01, 2008 | DISH Network IR Remote Control
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
189 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
