Question about Craftsman Garden
22hp intek eng stalls when hot starts and runs fine until it gets hot.
    Problem Solver:
  • 12 Answers
You have an overheating problem with your motor then. take it to the shop and have them check it.
Posted on Jun 30, 2009
I have a B&S 22hp Intek v-twin on a craftsman mower. It starts fine, runs great, but after about 10-15 min it starts skipping and will finaly die after another coupl min. As if it was running out of...
Mine did exactly the same thing until I figured out the replacement fuel cap I bought wasn't vented.I put a vented one on and away I went.Also check for a collaping fuel line,and check the screen inside the gas tank,those corrode sometimes.Hope that helps !
May 11, 2014 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22hp bs wont idle
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 22, 2012 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp not charging
if you have ever let the motor run whilethe battery is disconected even for afew seconds you will have burnt out the recterfier and there will be no chargeing of battery until the rectifier is replaced it is situated under the flywheel on top of the motor
Jul 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp Briggs problem. Loading up, runs
Try checking the prefilter on your air filter. I had a similer problem and mine prefilter was completly covered in dirt. I changed the air filter and it solved my problem. Also make sure the air intakes are not partially clogged with dirt or other stuff.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
193 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
