Question about Motorola Radio Communications
My motorola bluetooth h270 appears to be frozen. It won't power off, and won't connect to my phone. Whether switch is in off or on position, blue light stays on.
Put it on charging once again. While it is charging, switch it off. It should go off now. Now, remove from charging and switch it back on. Hope it works for you
Posted on Jul 30, 2009
Thanks - - I just had this issue for the very first time since I've had this bluetooth (about 3 years now) - and your solution worked. My question is - - why did it freeze like that in the first place?
Posted on Dec 10, 2012
Callers hear their echo when I use my Motorola h270
Alice
Does it happen only on your phone or when connected to other phones as well?
Motorola Support
Dec 10, 2014 | Motorola Mobility H270 Bluetooth Headset
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Hi lost my password for my bluetooth headset h270 how can i reset it to my new phone
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Feb 08, 2011 | Motorola Mobility H270 Bluetooth Headset
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
My motorola h270 bluetooth device will not connect to my sprint lg rumor 2 can you help me solve this problem. thanks
Charge your bluetooth device fully.
when ready, turn on your phone's bluetooth software (settings/bluetooth/on)
press and HOLD the power button on your device until it blinks 3 times (or continuously) wait for your phone to see it.
Usually the pairing code is 0000
the phone should let you know when it is complete.
Good luck.
Sep 27, 2010 | Motorola Mobility H270 Bluetooth Headset
Power switch light,won't go off the call light is solid blue and there is no reaction when I turn the power on or off
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Nov 25, 2009 | Motorola Mobility H270 Bluetooth Headset
Motorola bluetooth H270 solid blue light after pairing
Nov 17, 2009 | Motorola Mobility H270 Bluetooth Headset
I have a H270 Bluetooth headset. I charged it
Oct 27, 2009 | Motorola Mobility H270 Bluetooth Headset
Radio Communications Logo
2,988 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
