Question about Panasonic Workio DP-2330 Printer
PD-2330 & printing problem...
I have a unique problem. I HOPE that others have experienced it and found a solution.
When I try to print from TaxpPrep directly, the printout (the entire resulting page) is shrunk and printed into one quadrant of the page.
On the machine that has a problem, we are using Vista Ultimate.
So here is the problem....
1) It prints correctly from other machines that have Vista and Taxprep.
2) It prints correctly from other programs on that same machine.
3) TaxPrep print properly to other printers.
So it can't be the driver, because of #2
So it can't be the OS because of #1
So it can't be TaxPrep because of #3
The only work around we have is to print to PDF, and then print from there.
We are pulling our hair out. It is the only machine to experience this problem and we have reinstalled the OS, the Drivers and the program.
I really hope that SOMEONE has experienced this same problem.
5 Suggested Answers
  • 81 Answers
SOURCE: Booklet printing
You're right, most do offer that option from the print driver. I would check Panasonic's web site to see if they offer a postscript driver, that may have booklet printing.
Posted on Jun 12, 2008
komguy
  • 2306 Answers
SOURCE: p2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Posted on Jul 30, 2009
Geekman
  • 32281 Answers
SOURCE: Network printer printing rubbish when printed from Vista
The problem with dot matrix printers is that these are very old printers and you may not find a printer driver for them that run with Vista. If the incorrect printer driver is installed, the printer will print rubbish.
The only suggestion I can offer is to try various generic printer drivers until you find one that works. Connect it to the LPT1 printer port first and when you get it to work then set it up on the print server.
Also try Panasonic support and ask if they have a printer driver for this model printer that works with Vista.
Posted on Oct 22, 2009
KingDWS
  • 1606 Answers
SOURCE: I tried to print to
It has been a while since I've run across this but the printer you want to select is actually the Epson MX-80. That was the standard for narrow dot matrix printers. Panasonic equivalent was something like the KX-1180 but the Epson setting worked better.
And you will still have to adjust either the form layout or adjust the form template so the text ends up in about the right place. This is a pain to do but that is the only way if you have to use a dot matrix. Usually you only see these on multiple copy forms but most places have just changed to print multiple copies pages so I don't run across too many dot matrix printers these days.
Posted on Sep 02, 2011
Problem with panasonic dp-2330. i can not print from my laptop. i have the usb cable from my laptop to the printer/copier. i downloaded print driver to my laptop. the laptop recognizes the printer by...
You must enable the USB in service mode F5-88
While holding function key, hold original size ledger key, while holding those two, press the 3 key. This gets you into service mode. Press 5 then the start key. Scroll to #88 and set the value to 2
Apr 27, 2011 | Panasonic WORKiO DP-2330 Copier
I cant see where to fill in so that i can get an email adress
The sign-up page for Yahoo email can be found here:
https://edit.yahoo.com/registration?.intl=us&.pd=ym_ver%253D0%2526c%253D%2526ivt%253D%2526sg%253D&new=1&.done=http%3A//mail.yahoo.com&.src=ym&.v=0&.u=68kuthp6o9hie&partner=&.partner=&pkg=&stepid=&.p=&promo=&.last=
Ensure you select a unique Yahoo ID (use the "check" button to verify this) and also make sure that you set a good strong password.
Hope this helps!
Mar 19, 2011 | Yahoo Mail
I have a workio 2330 when i copy from the tray or table its fine but when i print from my computer the holes are on the wrong side. Its like it prints on the back of the page. How can i fix this? Thanks.
one of the settings in your print driver is wrong, try print without duplexing. i always recommend printing by default single sided and then select duplexing per print job.
Mar 31, 2010 | Panasonic Workio DP-2330 Printer
How to scan
My dp 2330 copier prints dark shades(0.5 thick dark lines) even though the text you want to print is seen in the back ground. pls what should i do or whats the problem? Thank you .
Sep 11, 2009 | Panasonic Workio DP-2330 Printer
How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
Aug 31, 2009 | Panasonic Workio DP-2330 Printer
Problem in Chinese chacracters printing , prints only junk !
there is nothing wrong with the printer ... the issue is the support in your computer for those languages...
May 29, 2009 | Computers & Internet
Panasonic 2330 servicecode
Try 0000. That´s the original operator code of my Panasonic DP-2330 office machine.
Feb 06, 2009 | Panasonic Workio DP-2330 Printer
Epson Stylys R300 not printing black
have you tryed a head clean? try this if it still does it what i did when mine did this i found it was the ink cart take the ink cart out get a cotten woolplug cut one end off and stick it in the bottem of the ink cart with the other end that still got the wool on just clean insite printer where cart goes regards mark
Sep 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Booklet printing
Jun 12, 2008 | Panasonic Workio DP-2330 Printer
Networking a Panasonic DP-2330 Multifunction printer/copier.
Hello the MAC address is #28 located on the General Setting list under Function menu. Print it off. The key opp code is ussally 0000. Good luck I am in the same boat.
Feb 17, 2008 | Panasonic Workio DP-2330 Printer
Panasonic Workio DP-2330 Printer Logo
48 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
