Question about SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
My 250 GB signature mini is not connecting to my computers. Why and how will I solve the problem?
    President:
  • 261 Answers
Change the usb cable and use shorter one
Posted on Nov 29, 2011
I have a Simpletech signature mini 250 gb external hard drive,it shows as unknown usb device and has no drivers.Do you know where I can download these missing drivers?
hi your hard disk got problem
but check in control panel > administrator tools> disk managment if there is any drive that not formated you lost your partition or got viruses otherwise your hard disk physically is damaged
Sep 01, 2011 | SimpleTech Signature Mini 250GB External...
I've met space limit for my SimpleTech external drive even though my internal drive still has space and both are 250 GB. Are there SimpleTech programs taking up space and if so how much of that 250 GB...
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
Aug 21, 2011 | SimpleTech Signature Mini 250GB External...
My simpletech 250 gb external hard-drive is not working. anyway to fix this manually?
change the usb cable firstthen >control pannel > administrator tools> disk mannagment if there is any physicall disk so ask again
Jan 10, 2011 | SimpleTech Signature Mini 250GB External...
Computer not reading hard drive
Usually a brand new HDD needs to be formatted.
Have you done that?
If not, then you should do as follows:
Right click on My Computer, click on manage.
A new window, called Computer Management. will appear.
Click the option Disk Management from the left pane.
On the right you will see ALL the drives connected to your computer.
Select the one you want top format, right click it and choose FORMAT.
When the process is completed, you'll be able to see and use your new HArd drive.
Hope this helps.
Jul 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
My signature mini hd doesnt work........
With this situation, only a data recovery company can help you. I am afraid that there is some mechanical damage to either the case or the hard drive. If you can remove the case and test the drive, you may be half way there, but if drive is clicking, it is best you leave it to professional data recovery. That is what I do, but you don't have to send it to me. You can bring it to your local shop to see if they can help.
Jun 19, 2009 | SimpleTech Signature Mini 250GB External...
USB problem
i) connect it at the backside of your computer(in the usb ports), mostly these(usb with huge space) are not compatible with usb ports on the frontside or front panel of your computer tower...
Thanking you,
M. Sridhar
Jan 01, 2009 | SimpleTech Signature Mini 250GB External...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow Logo
216 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
