Question about Whirlpool Freezers
Whirlpool side by side (Model # ED5PHEXMQ00) Not cooling.
Both the Freezer and the refrigerator stop cooling.
WhIzAtIt
  • 136 Answers
SOURCE: bottom refrigerator not cooling
The defroster timer, or the defrost element could be out. Also the blower motor in the freezer could be locked up. If you can hear the blower its likely the timer or the element.
Posted on Mar 13, 2008
tomsat69
  • 219 Answers
SOURCE: I have a maytag side by side refrigerator freezer
Sound as though you need a defrost timer that is located around temp control and light in fridge side.If it is faulty it will not go into a defrost making the freezer ice up and cause alot of trouble.hope i helped thanks:)
Posted on May 12, 2009
  • 111 Answers
SOURCE: refrigerator just stopped cooling all of a sudden.
is the compressor running ? if yes feel the cooper tubes around , the tiniest one is suppost to be hot if is not hot u have a leak call a tech . if it is hot open the freezer and take the back cover inside of the freezer if the coil is totaly covered with ice you have a defrost problem , check the timer , bimetal and heater
Posted on Jun 19, 2009
apexappli795
  • 46 Answers
SOURCE: refrigerator part does not cool but freezer part does.
check to see if the evap fan is blowing behing the freezer wall. if not it may need to be replaced. is there ice forming on the wall of the freezer? If so you might have a defrost problem.
Posted on Sep 17, 2009
SOURCE: model # ED5RHEXMQ00 whirlpool refrigerator my
is the unit running? if not thats your problem If the unit is running, check the compressor, check all other motors are running, check for excessive frost on evaporator.
Posted on Oct 12, 2010
The freezer stopped working and maybe the refrigerator too but there is light inside when I open the door. Water is leaking from the freezer door perhaps coming from the melting ice.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Whirlpool Freezers
I have an EV187NYRQ04 Whirlpool Freezer. There is a constant buildup of ice in the bottom of the freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 07, 2011 | Whirlpool Freezers
Hello, I have a Maytag side by side fridge that is 26 cu. ft. The freezer has stopped working and the fridge is slowly getting warmer. I have tried unplugging it and plugging it back in. This has not...
heatman101
Jul 06, 2011 | Maytag Freezers
Vents in the bottom compartment getting block ice
heatman101
Jun 25, 2011 | Whirlpool Upright Freezer EV161NZRQ
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
heatman101
May 01, 2011 | Whirlpool Freezers
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
Feb 15, 2010 | Whirlpool Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Freezers Logo
142 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
