I MICHAEL ANTHONY GONNZLES TRYING For The 100 DAM TIMES to set A New gmail account MY Old one MikeGlocos @ gmail. Com Has been Mest With I want to put new one [email protected]
Go to the emails in your settings menu, you should be able to see a log off button somewhere in there. Then you log on with your old username and password.
Hi Anthony, yes you can change your G'mail emailing address if you wish to, and to do that go to gmail.com and click on open new ACCOUNT OPTION and you will be up and running once again, good luck
It sounds like you are trying to access your old gmail account by signing on where you create a new gmail account.
Instead of signing on that way, see if there is a place on the gmail page to "sign on with a different account", and proceed from there.
John
Probably the best and easiest solution is to set up email forwarding from your old account to your new account. If not, you will need to basically download all your email from your old account and upload it to your new account. This will require some type of desktop email client and quite a bit of setup.
You will most likely need to create a new Gmail account in order to change your address. Make sure to back up your current Gmail account so you can import your old mail into your new account.
You could also set up forwarding from your old account to the new account. This way any emails sent to the old account will be forwarded to the new account.
After creating new account on google.com.tap settings on iPad,tap mail,tap gmail to delete old account..tap mail again on top left then tap add account,tap gmail then enter info for new account.
