Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Brush will not rotate - belt is not broken - Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
    Problem Solver:
  • 16 Answers
Replace belt It's not broken but its loose & its slipping over the motor shaft
Posted on Jun 30, 2009
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
Why doesn't the brush roller rotate?
Hi, this is Jim with Crucial Vacuum,
The belt may not be broken, but it may be lacking in tension and therefore unable to rotate the brush roll on its own. You're going to want to replace your vacuums belt every 3 to 6 months depending on usage. Check to see if the belt is loose, or over stretched.
Check the brush roll as well and be sure its securely locked into place. It could be slightly loose causing a lack of communication between itself and the belt. Our video can help with fitting the belt in properly with the brush roll:
https://www.youtube.com/watch?v=LRV8280PQxc
You can purchase replacement belts and brush rolls for your Hoover Linx directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-linx-platinum-roller-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 05, 2015 | Hoover Platinum LiNX Cordless Stick Vacuum
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
Belt not broken.... brushes will not rotate.
most have two belts, brush roll rotates only when head is level with the floor....
Feb 19, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush is not rotating and I get a smell from the
It might be the drive belt. If it is stretched, worn or broken it will not turn the brush roll. You can get replacement belts here:
Replacement Vacuum Belts
Nov 24, 2009 | Vacuums
The brush on my bagless vacuum won't rotate. It
if the brush doesnt rotate, the belt is either broken or stretched. If you have a Dyson, you will have to replace the entire assembly for about 80 dollars. Other brands you can simply replace the belt for about 5 dollars.
Sep 05, 2009 | Vacuums
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
153 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
