Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
32in Westinghouse lcd / picture scrambled
When I first turn on my tv the picture is scrambled but after 30min to an hour it will clear up but sometimes it will go back to rolling and scrampled pic but other times it wont do it for 5 or 6 hours. Lately it is taking longer and longer to clear up when I turn it on and sometimes it won't clear up at all and I have to turn it off and try again. Any suggestions would be greatly appreciated.
My westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Posted on Nov 13, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
The tv will run pefect for some time 30min to 4 hours , the picture will start jumping and then go into hundreds of lines and colors. Sound still works great. Can unplug for 30 min and will run again...
Your signal board is defective. It is the board with the antenna connection and all the audio video connections. If you open the TV form the back you can get a part number from the board and order it on line. You can find parts at www.interliquidparts.com Be carefull tv's have high voltage make sure it is unplugged for a few hours before you take off the back cover.
Jun 03, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
I purchased 2 32in Westinghouse LCD HDTV and one 42in LED HDTV, BOTH the 32in LCD TV's have a volume that will not stay below max. Sometimes the volume bar will go away I can lower the volume, release the...
there may be some other source of intereference within the area that you have the tv placed try moving it to a different area and see if that works you are dealing with electron magnetic interference and infared waves
Jan 27, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Vertical colour bars
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Feb 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
It turns on fine and looks fine but after 30min the colors explode and looks horrible u can turn it off and wait 30min and turn it back on and works fine for another 30min or so. thanks for the help
Try running it with the back remove (you can put the stand back on after the back is removed) and have a small fan blowing on the top section of the TV where the LCD controller board is, see what the LCD controller board looks like here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Dec 10, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
MY WESTHOUSE 32IN LCD HAS RED PICTURE AND THEN TURNS TO LINES ALL THROUGH SCREEN
Check and re-seat the LVDS cable. If that doesn't help then the LCD drive board ( t-con ) is bad.
Nov 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My Westinghouse LTV-27w6-HD picture is scrambled periodically
Before you bother to read the text below, you might be better served looking at this thread:
Westinghouse troubles
If you aren't nauseated yet, continue with my original reply:
If the picture seems 'pixelated,' broken up into randomly sized and placed blocks, then it is losing synchronization with the digital signal coming in. This is certainly repairable and may be due to lousy assembly quality rather than a failed part. Most of our modern sets are assembled by robots but there is a degree of manual soldering still to be done and this can result in 'cold' solder joints that can fracture and fail due to heating and cooling of the innards of a set.
Unfortunately, unless you have a semi-retired TV service man in your neighborhood who is already financially independent, the labor costs could run fairly high for this kind of service since it requires methodical searching of the circuitry and could eat up some time.
Jul 24, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
807 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
