Question about Canon PowerShot S300 / IXUS 300 Digital Camera
Camera ixus300 digitl camera for download into pc
Pl help us to download the software for camera ixus 300 digital
SOURCE: canon digital ixus 700
I understand that it takes a maximum of 2GB. Still loads of photo/video capability. Don't make the mistake I did of buying a 4GB SDHC card for it. It won't take it.
Posted on Sep 28, 2008
  • 19396 Answers
SOURCE: Reqd Driver Software for anon Digital camera Powershot A400
Here the download page, scroll down the page to find software download, you will need to download more than one driver.
Posted on Feb 17, 2009
  • 93798 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
SOURCE: Where can I download a manual for the Canon IXUS V
Posted on Jun 18, 2010
Testimonial: "Well done. That did it too. Many thanks"
  • 420 Answers
SOURCE: PowerShot SD940 IS / Digital IXUS 120 IS Digital Camera: My Digital IXUS 120 IS has lens error, with a mess...
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
  • 6831 Answers
SOURCE: HiI have a Canon IXUS 80 IS digital camera. The
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Posted on Sep 30, 2010
0 characters
1 Points
Where can i download software for canon ixus 300 HS digital camera
The IXUS 300 HS is called the SD4000 IS in some parts of the world. You may download the SD4000 IS software from here.
Bear in mind that you don't need to use the Canon software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Canon ZoomBrowser or Picasa.
Nov 12, 2012 | Canon SD4000 IS IXUS 300 HS Digital Camera
How to solve memory card error on canon ixuis 100
Hi T A Ankam,
Try another memory card please but first,check whether the one you have is locked.Some Cards do have a lock on the side.Unlock it and then insert it back into the camera.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Digital Cameras
I have a new Dell Inspiron with Windows 7. No matter what I try I can't load/download a driver for Canon Ixus 300. I have the CD, but it is not compatible with Windows7.
Your CD is for an older version of Windows and the installers/drivers have changed over time. The driver you need is part of the Windows 7 OS so you should be able to just connect the camera to the computer using the appropriate USB cable.
The software update for the ZoomBrowser EX is available here: if you need. Use the drop-down menu to select Windows 7. Download and save the file. Then launch the updater (double-click) and insert your CD in the optical drive of the computer. Then follow the on-screen directions to install the ZoomBrowser EX version for Win7.
You can import from the camera with Paint (File > Import from Camera or Scanner) and PhotoGallery (if you have the Windows Live package installed)
I hope this helps.
Dec 22, 2010 | Canon PowerShot S300 / IXUS 300 Digital...
I lost my cd
search for your cannon model number on canons webpage and download the software. You should be able to use the camera via usb without it though. Your pc will see it as an external storage device. Your pics will be in the DCIM folder.
Aug 10, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Download pictures from camera to computer
Yes you're correct that you should be using a software for the camera that you can use to trabsfer file from camera to pc.
You should have the setup CD that came with it.
Hope it helps....
Jun 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
For Windows XP you actually don't need to install anything to connect your Canon Ixus to your computer.
You can download other Canon software from here
Apr 16, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Download pictures
Hey there montrealaise, the model pwershot s300 is also known as the IXUS 300. The software is specific to your OS, so choose the appropriate downloads for your system.
If the link does not work, just copy and paste to your browser window. Good Luck!
Feb 25, 2008 | Canon PowerShot S300 / IXUS 300 Digital...
Canon PowerShot S300 / IXUS 300 Digital Camera Logo
48 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
