Question about Kirby Vacuums
I am very unhappy with my Kirby. It's nothing like the demo they showed me. It won't even get lint off my bedroom carpet and I only had it for less then 2 months and the belt broke. I want my money back and I'll give the Kirby back!
  • 75 Answers
Give it back to your kirby dealer.
Posted on Jun 30, 2009
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
Why won't my Kirby carpet cleaner disperse
check all conections are on tight and no brakes in them this link may help you
http://www.goodvac.com/Articles.asp?ID=153
May 08, 2013 | Vacuums
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I recently purchased this vacuum after reading consumer reports article on it and from recommendations from family. However, since I've had this vacuum it's been nothing but problems! I have a frieze...
is that a shag carpet? the power head is raised up all the way can you lower the suction on it is the carpet old the vacuum may not be able to handle the carpet,go to a vacuum store and see if you can try somthing else out some stores well let you rent them out kirby is a good vaccum i think my grandmother had the first models when they came out and it still works to this day my mom has a kirby she bought in 1975 and basic tune ups it works great and the use to have the long string shag carpet.and yes it had to be on its highest seting.well i hope this helps thanks
Nov 29, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Kirby G5 carpet cleaning system
Try my online guide and follow the directions carefully and exactly. If you do it the way it says and you don't miss any steps, it should solve the problem.
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Jan 07, 2009 | Kirby G5 Bagged Upright Vacuum
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
