The door on mu drive wont open unless i help it with a paper clip. like it gets stuck when it all the way closed. if i can get it to move out just a 18th of an inch it will open every time. should i lube it up or something?
  • 52 Answers
This means that the track of the drive door became dried...you'll have to lean the drive and put some track gel on it with the help of a service engineer...
Posted on Jul 05, 2009
How do I open the disk door
if the small button on front of door wont do it (power on) then the door maybe stuck or sometimes they ignore you request to open if its trying to read a corrupt disk (kinda a loop thing ) If that's the case try turning power off and hold open button down as you return power to on (the whole way) this works 4 me
Aug 12, 2016 | Acer Computers & Internet
I can't get the draws to open to play my dvd's
If the open button doesn't respond, you mu...
  1. Step 1: The paper clip. Straighten out one leg of the paper clip.
  2. Step 2: The small hole. Find the small hole on your CD drive, it is usually near the button.
  3. Step 3: Stick the clip into the hole. Stick the clip into the hole and gently push until the door opens.
  4. Step 4: Finish.
How to open jammed CD DVD drive
Oct 02, 2015 | RCA RTD217 Theater System
HOW DO I OPEN THE CD DRIVE
Hello. The stuck cd drive door. Bin there before. Use a paper clip, bend out one of the arms of the paper clip. Look for a tinny sized pin hole on the cd drive door. Use the paper clip as a push key. Put the paper clip leg in to the hole, lightly push in and pull the cd drive door lightly toward you. Then you can take out the cd and push to closed the door. Then you can use the computer as before. But remember to keep the paper clip as your emergency key. Good Luck.
Jun 03, 2014 | Packard Bell Computers & Internet
Hp pavillion wont eject dvd
Turn system off and use a paper clip to manually open the drive door. Straighten a paper clip, then insert it in the small opening to the right of the eject button. This should manually open the door and you can remove any disks in the drive. Then reboot and see if it will open and close normally.
Jan 16, 2014 | Dell (0F146) Internal DVD Drive
DVD stuck in my Yamaha DVD-c6761 DVD/CD player. How do I get it out so my player will open and work properly again.
Unbend a paper clip.Look very closely at the area around the CD/DVD drive door until you find a really small hole - it almost looks like an accident (probably just below the door). Insert the paper clip in the hole (don't be afraid). Push the paper clip gently to press the spring-loaded latch.Your CD/DVD tray should open right up. That's it. Deals Prices
Jan 10, 2014 | Audio Players & Recorders
We have a computer model T3092. The compact disc section wont pen and it has a cd stuck in there. How to open?
Look closely at the front of the drive. There is a small hole, usually right under the slot door. Get a paper clip and unroll it. Push the paper clip straight through the hole. You should be able to feel it when it releases the catch on the drive door.
Hope this helps.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | E-Machines eMachines Desktop PC
Cd Stuck
Look at the "door" or "flap" of the cd rom drive. You should see a small round hole. If you straighten out a paper clip and insert it in the hole, push in gently, that will open the door and eject the disk. Please rate this if it helped you.
Jan 17, 2009 | HP Media Center m7060n PC Desktop
The cd door is stuck - i cant open the door or close it, help? Tray does not open when switch is depressed. Green light burns steady.
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Apr 18, 2008 | TDK (DVD+RW47BXS5) Storage Media
C d door stuck
you can find a small hole at the front side of your cd drive , carefully insert any pin inside this hole and press it , your cd drive door will open.
Some time holding the cpu in 90 degree angle while system is on and pressing the eject button releases the cd door.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
202 people viewed this question
Alun Cox
David Payne
David Payne
