Question about Panasonic KX-P2023 Matrix Printer
Panasonic kx p2023 with a Mac system os x10.39
How can i put my panasonic kx p2023 into the Epson LQ 850 mode? I think I need this in order to use it with my MacIntosh computer. If you have an alternate solution, that is of interest as well. thanks
    Problem Solver:
  • 10 Answers
Re: panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
Posted on Feb 11, 2008
0 characters
3 Points
Panasonic kx-p3626 Driver in window 7
We recommend you use the below link to review all available drivers and software.
Mar 06, 2014 | Panasonic KX-P3626 Matrix Printer
I want to download Panasonic Printer Model NO. KX-P1131 for windows 7
For your "Panasonic KX-P1131 Matrix Printer" just use the "EPSON LQ Series 1(80) INBOX Driver" for Win 7(X86 or X64) from your Win 7 CD. Select the LQ 850 Epson driver from add printer and & install the drivers and it will print just fine.
Reference link @
Hope it helps.
Jun 13, 2011 | Panasonic KX-P1131 Matrix Printer
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Panasonic kx-p1121 driver
Dot matrix printers usually work with IBM compatible native drivers. I have tried similar model with Vista worked fine. You may need to perform manual installation by using LPT1 parallel port. If you cant see similar model in the list you can choose generic text printer or IBM Proprinter.
Good Luck
Nov 10, 2008 | Panasonic KX-P1131 Matrix Printer
I have the same problem with my epson CX3810. Paper won't load or advance. Any solutions???
Feb 13, 2008 | Panasonic KX-P2023 24-Pin Impact Printer
If your looking for the printer driver, it should already be in the computer. Windows 2000, XP and Vista all come with the KX-P2023 driver pre-loaded. If you can't find it, you can use just about any of the KX-P2000 series drivers that are pre-loaded wqith Windows.
Oct 15, 2007 | Panasonic KX-P2023 24-Pin Impact Printer
Panasonic KX-P2023 Matrix Printer Logo
206 people viewed this question
Top Panasonic Printers & Copiers Experts
Mohan Sriraman
Mohan Sriraman
Are you a Panasonic Printer and Copier Expert? Answer questions, earn points and help others
