Fan stays on
INTERTHERM fan stays on (indoor unit). Outside unit works fine cuts on and off with thermastat.
  • floelect Jun 30, 2009
    This intertherm is in a mobile home. I have had continuous trouble with excessive water leakage. I fixed that by tilting the drain pan. There has been a slight delay between indoor fan and out door fan. however,now the indoor fan will not cycle off. only by flipping the breaker will the indoor fan stop. this is not characteristic of the original operation.
  • 378 Answers
The indoor usually on contentiously only the outdoor unit On and off to control the temp.
Posted on Jun 30, 2009
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
I have a 901650 intertherm and the fan outside turns on but the air conditioner inside does not work. What could it be?
!st off, do you mean the indoor unit does nothing period as wont run? or wont cool?if it wont run, the checking breakers/fuses etc is a waste of time, as the transformers clearly providing the 24 volts to operate the contactor outside.If you switch your fan to "on" does the fan run?if not, check fan relay, or board or motor/cap etc.If the fan does run with the fan switch set to on, but not in cool mode, the auto function that sends power to green /fan via yellow?cool terminal in the tstat is open and not allowing the 24v to energize the fan relay.
Feb 24, 2012 | Heating & Cooling
We just moved this ancient Intertherm air conditioner. It worked last year before the move. You can hear it running and the fan to blow hot air outside is running however no air comes out of the air vents.
Hi , I believe the old intertherm requires that you have the "g" wired in on the thermostat before the indoor blower will work. If this is on a mobile home, you may have only 3 wires on the thermostat. Y, G, and R. Y is for the compressor, G is for the indoor fan motor, and R is Hot (transformer). Make sure these are all connected to the thermostat as well as the outdoor unit.
Check to make sure the thermostat wire that goes from the thermostat to the unit is not freyed or chewed. This happens a lot.
If this fails, take the side panel loose on the unit that will allow you to view the motor. You might be able to visibly see a problem.
Make sure your ductwork is not pinched also.
Hope this helps you.
Aug 06, 2011 | Heating & Cooling
My intertherm ac unit is freezing up outside ,why? are there any recalls on these units
Few things cause this. Poor or no airflow inside the furnace, dirty filters, poor filter placement that will cause your indoor cooling coil to plug with dirt, or low freon pressure.
Jul 26, 2011 | Intertherm P3RA-048K Air Conditioner
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
I am trying to get some information on Intertherm unit on the inside of a Manufactured Home, With the new Hud requirements they are saying the out door unit must be installed by the manufactures...
Hi, since you live in a Manufactured home and not a R.V., I see no reason why you cannot go with what ever type of condensing unit you want to install on a slab outdoors. The installation instructions for the Intertherm unit for installing the outdoor unit should apply to any brand unit you want to use as long as the size of the indoor coil is the same capacity of the outdoor unit. For example, if the indoor unit is a 2 ton, 2.5 ton, 3 ton and so on, the outdoor unit would have to be the same is all. Same freon type, most are R-22, but they are using the new R-410a freon, so make sure of the freon type of the indoor coil is and get a unit of the same size and freon type. The installation instructions for the Intertherm should almost be the exact way to install any other condenser. Look for things like the distance from the outside wall, if it needs to be anchored, how far away the electrical disconnect box has to be from the unit, example 4' to 6'. Things like this you need to look for in the installation instructions is all. The new condenser unit holds enough freon for up to 25' of copper line set also. Try to stay with in that range to the indoor unit. If not, no big deal, they may need to add or remove a little freon is all. I hope this has been helpful to you on this. Trane, Carrier, Rheem, Ruud, Bryant, are all top of the line, better made then Tntertherm in my opinion. They should all be hud approved, I don't know where you are from, but here in Ca, they are.
I wish you the best, and please don't forget to rate me. I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Aug 06, 2010 | Intertherm Heating & Cooling
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
Ac is not blowing air the house, but the fan outside is working
There is not much information to work with here. Here are the possible problems listed in order of most common in my experience.
Frozen system caused by Low refrigerant or blocked air flow.
Indoor fan has failed and needs to be replaced
Indoor fan capacitor has failed and needs to be replaced
The fan relay that is on the circuit board has failed and the whole board should be replaced.
The system has a wiring problem (bare wires or miswired)
Jun 23, 2008 | Intertherm Heating & Cooling
Heating problems
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Jan 15, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
