Question about Epson Stylus 1400 InkJet Photo Printer
The print-out has several vertical lines
My one year old epson keeps printing color vertical lines all over my graphics, i tried cleaning heads, alignment etc, but none of them worked. When printing back and white document, it would skip a vertical line then carry on printing the document
  • jennychrist Jul 01, 2009
    But this is an injet printer
  • 52 Answers
Needs a new printing ribbon.
Posted on Jun 30, 2009
My epson 434 is only printing partial lines, or 1 line and not the next, its not even a year old, how can i fix this
You need to do a head clean it could take several goes to fully clear.
To do a HEAD CLEAN go in to Maintenance settings then click on HEAD CLEAN
After this it should offer to do CHECK NOZZLE print or this can also be found in Maintenance settings.
All the colours should print perfect lines with no breaks in them.
It is an ink eater so only do as you need.
Let me know how it goes.
Regards Craig
Feb 03, 2018 | Epson Office Equipment & Supplies
HEAD CLEANING DOES NOT FIX GAPS IN NOZZLE CHECK
Head cleaning is for fixing horizontal band. If some point of head cloged, print out will show horizoantal banding. For vertical banding, try using head alignment. Have yo tried printing without high speed (disable high speed option)
May 20, 2010 | Epson Stylus C84 InkJet Printer
Jagged lines on paper
You did not say how much printing you do. A year old printer that is heavily used can have quite a buildup of ink. It may need the entire paper path and mylar strip professionally cleaned. It's not a big deal, but the printer covers do have to be removed. This is best accomplished by an Epson Certified technician, usually employed by one or more of your computer dealers or sometimes office supply retailers.
If you bought the printer locally, I'd first try there. If you purchased it from Epson Direct or from another online retailer, try Best Buy, Office Depot, or perhaps Staples. If they do not provide such service themselves, they may have a recommendation for a reputable business that does.
Feb 18, 2009 | Epson RX595 Photo All-In-One Printer
My epson cx6400 printer won't print it not been use for several
I'm not sure what you mean by not printing, is it trying to print but only blank pages?
Make sure its on and the "!" is off.
Try copying first using the unit itself since this is an all in one printer. If it prints then we know its working.
If scanner is not working you can try printing without using the scanner featured on the unit. press on the setup button use the left or right arrow repeatedly and select on nozzle check then press on the color button.
If it prints but the pattern is incomplete (gaps or breaks on the lines) you can try head cleaning.
Press setup use the arrow left or right repeatedly and select on head cleaning then press on the color button then it will clean it.
Make sure that everytime you clean it you have to print on a nozzle check so that you will know that it prints properly.
If there are no gaps or breaks on the lines print on a document or picture it will give you good printouts
Feb 12, 2009 | Epson Stylus C86 InkJet Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Hi, I have an Epson Stylus 4000 printer at home. I had no problem printing high quality prints untill now. I thought that my nozzles were clogged (I haven't use it to print for a several months), so I...
print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
Aug 27, 2008 | Office Equipment & Supplies
Printing issues
I would get it repaired. you could get one off ebay. they are a lot of money new.
Mar 21, 2008 | Epson Stylus Photo 1280 InkJet Printer
Prints yellow vertical lines on all color print jobs
Try to do a nozzle check/ Turn printer off/ put in a plain paper
Press and hold the middle button on the printer while turning it on. When it turns on you can realease the buttons. Should [print the nozzles/ check if there would be gaps of missing colors/ if yes do head cleaning by going to printers and faxes under contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Jan 21, 2008 | Epson Stylus C66 Inkjet Printer
Epson Stylus CX6400
Blank pages are indicative ofdried ink.
If the printer has not been used for a long time ink may have settled and dried in the heads.
You may need to replace the cartridges (IF they are very old) and run several head cleanings if there is no improvement.
I typicall try to print a few test pages to see if some of the color work.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Nov 11, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Prints fist lines onlyTrying to print a list
Clean the head - first in control panel, doubleclick on 'printers and faxes' then right click on your printer and click on printing preferences then when the window opens up on your left at the top - click on maintenance to clean the head.
May 27, 2006 | Epson Stylus C66 Inkjet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
1,326 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
