My Trutech KLV3170 is not receiving digital picture
I have a Trutech KLV 3170 Under Cabinet tv/dvd/radio. I've hooked up the converter box but I'm not receiving any pictures or stations. It shows a blank blue screen. What am I doing wrong? How can I fix the problem
techman
  • 3130 Answers
SOURCE: Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Posted on Oct 15, 2006
SOURCE: No picture just sound Polaroid 7inch TV/DVD
I owned the under the counter since jan 07 and the same problem. Called poloroid and they said the warranty is only for 3 months. Since I purchased it on ebay they said i have no warranty since i purchased it through a 3rd party. they said they would replace the tv for $60. plus s&h. WOW SOME COMPANIES JUST DON'T STAND BEHIND THEIR PRODUCTS. CRAP PRODUCT DON'T BUY IT.
Posted on Mar 25, 2007
  • 205 Answers
SOURCE: picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Posted on Jan 01, 2008
SOURCE: Space Saver Kitchen TV TruTech KLV3170
Thanks so much. I was told there is a circuit board problem and dumped the TV.
I appreciate your prompt response.
Sandrap85
Posted on Nov 06, 2008
SOURCE: Magnavox Converter Box quit working
Can't really say my problem is solved Called the 1-800# and spent more than 1 hr. talking with various people and the consensus is that the Box is defective. Common sense and no real knowledge of electronics told me that before I ever called.
Solution - UPS will pick up the packaged Box between 8AM and 7PM today - very specific time!!!!
I will have a new one in 6-8 wks and by that time I will have NO TV reception. Asked if they could possibly put a RUSH on the order but that's like asking if I could get an invitation to the Inauguration!
Lots of frustration for purchasing an inferior product.
Thanks for your concern and prompt response
Posted on Jan 15, 2009
I have a trutech tv KLV3170 but I've got a rca universal remote I need the code for it
047,029,084,092,000,055. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 19, 2013 | RCA Universal Remote Control
No color TV on my Trutech 7'' LCD TV + DVD under the cabinet model KLV3170
The TV broadcast system in Brazil is PAL-M.
If this TV was bought from the US then the TV will be expecting the NTSC system.
Your other American TV may be a multi standard TV and is able to detect and adapt to your PAL broadcast system. Not all TVs do this.
How do you connect the DVD to the Trutech TV? Is it with a Scart connector? If so then the TV will not be using any broadcast standard at all and that is why it works properly.
Unfortunately if you have searched all the menus and manual instructions without finding a TV system selection, then this TV may never be able to receive TV broadcast in colour.
Nov 24, 2007 | Televison & Video
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Since the switch to digital transmission, my antenna no longer works with my Trutech 19 inch TV. What kind of antenna do I need to buy in order to get reception?
to add to what MIKEY-MOORE wrote, OUR government was offering discount ($20 off a $40-$45) coupons on a digital converter box that you can use your original antenna ( I still use my original nineteen and 65 (1965) rabbit ears antenna) to receive the digital signals NOW being transmitted through the air. In order to receive the signals YOU MUST get the converter. GOTO any Radio Shack, Walmart, to acquire the converter box. You will need one for EVERY tv in your house. I have a HDTV (but not digital) and I had to buy 3 boxes.
Jul 17, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Hi what do I need to receive the new digital from an antenna for my SONY LCD COLOR TV KLV-S32A10 thanks Marilyn
You will need to buy a digital converter box!
You can get one online or at a wal-mart or radio shack!
Please rate my response and help keep this site free!
THANK YOU!
Jan 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Trying to hook PS2 up
u cant play them on it its a dvd player
Dec 12, 2008 | TruTech PVS12701 Portable DVD Player
Digital converter box
Greetings kathy76turne,
In February 2009 you will be unable to receive ANY analog television signals therefore the digital converter box will be a necessity to receive any over the air broadcasts.
I am unable to answer the question about the mini van's electrical capability, however you might find the following link handy to get more information.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat120600050013&type=category
Thank you!
Dorothy
Go Ahead. Use Us.
Jun 09, 2008 | Mitsubishi HD-6000 DTV Receiver / Video...
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
