Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
GE oven won't heat
My GE oven won't heat. When I press bake or broil, a small light starts flashing on the control panel and nothing heats up.
  • 4 Answers
Get it cleaned
Posted on Jun 30, 2009
  • ovenoscar Jun 30, 2009
    get it cleaned
My oven won’t heat up
Could be the bake element or the board If it has a oven control board. If the board is bad it won’t bake or broil so try broil if that works it’s the bake element that you’ll need to replace
May 08, 2018 | Ovens
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
166 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
