Error code f -05 - Washing Machines
  • bosch5 May 11, 2010
    make model
  • 15,935 Answers
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I get an error 05 on my SINGER Futura xl-550....i have it set up to embroider and when i turn the machine on I get the error and the arm does not move
You need to find out what error 05 means. Usually, you will find that information in the troubleshooting section of the owner's manual. If not, you can search for:
Make Model error code 05
You may need to contact Singer Support if you can't locate an error code list.
Feb 28, 2018 | Singer Sewing Machines
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Printer canon mp258 scane problem error code 2,140,2 give me solution
  • kishor kumbharePrinter canon mp258 scane problem error code 2,140,2
    May 05, 2013
    May 05, 2013
Jan 01, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Error code 5
Corrective Action
Aug 11, 2010 | Precor EFX 546i Elliptical Version 4
Receiving and Error Code 5
Error 05 points to a problem with one or both reel motors. Not field-repairable for a non-technician.
Mar 25, 2009 | Sony PVW-2800 VCR
Error Code E-05?
Error code )% i think means no focus, you could try cleaning the laser, but otherwise its a replacement laser :(
Regards
Mark
Jan 18, 2008 | Kenwood KDC-MP4032 CD Player
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
