Question about Olympus Stylus Zoom 140 35mm Point and Shoot Camera
Lens won't retract and it makes a racheting noise when battery is inserted. Can it be repaired?
  • 3 Answers
Most probably and or dirt has gotten into the lens mechanism, could also be a damaged or worn drive gear. Can you see score or scratches on the lens barrel? If the camera is still working then I would keep on using it. A repair would not be economical so a replacement is the only option.
Posted on Jun 30, 2009
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens doesn't retract
This might be a lens fault and a repair is recommended.
If it also switch off when not retracting then it could also be a no power issue.
You could try following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 11, 2009 | Kodak EasyShare V1003 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Lens/focus err
I had the exact same problem in September 2007 (must be built in obsolence). I sent mine to Fuji's repair center to get repaired. Unfortunately, it becomes a decision of whether to get it repaired or buy a new one (repair cost ~$160). The kicker is now the flash will not work. I get a message/warning of camera shake. The manual says it's something to do with the shutter speed but no mention on how to correct it. So it becomes another decision of do I throw more money at it (send back for repair) or bite the bullet and buy a new camera.
Oct 23, 2007 | Fuji FinePix F700 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Olympus Stylus Zoom 140 35mm Point and Shoot Camera Logo
152 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
