Masterbuilt 20070106 Electric Smoker Logo
A
Anonymous Posted on Aug 03, 2014
Why would the control box turn off during cooking or when checking meat temperature?
Control shuts off during cooking at any time or when checking temp probe reading. Rechecked control electrical connections made in assembly.
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 • Cooking
HOW LONG DO YOU COOK A TURKEY
Hi Kathy.
Happy Holidays. The answer to your question is 'it depends'. On size of turkey, how you cook it (deep frying is faster than roasting, for instance, while smoking is really slow), and how you're judging it to be done. The most effective, and safest way to assist the cooking is to have a meat thermometer that can be inserted into the deep part of the ,er, white meat (the word police tagged me here) to monitor when it gets to a target temperature, usually in the 160-170F range. If possible, it's a very worthwhile investment to get a remote probe thermometer, with a cable that snakes out around the oven door and displays the meat temperature. Opening the door all the time to check temperature lets the heat out and runs the cooking all day.
I'm a big fan of the Alton Brown/Good Eats recipe
Good Eats Roast Turkey Alton Brown Food Network if you have the time ahead, the brining really makes for a moist tasty bird, and the actual cook time is usually between 2 and 3 hours, depending on the bird size. The initial high heat sear makes for great browning and crisp skin.
As a general rule, allow 20-30 minutes after baking for the turkey to rest before carving (cover in foil during this time). It'll cook a bit so as not to burn you while carving, and the juices re-absorb into the meat. (carve right away and a lot of the juice will run down onto the carving surface.
Bon Apetit!
D
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 • Grilling
1helpful
2answers
I need to know the cooking times for my chicken
Use a thermometer and measure the chicken, keep track of how long it takes then you have the time it takes to cook that piece. It is always best to use a thermometer when cooking meat.
Generally I bake chicken at 350 degrees F. for 30 to 40 minutes. To be sure that the chicken bre asts are cooked thoroughly, use a instant digital Cooking or Meat Thermometer for the proper temperature of 165 degrees F.
These links will help.
Safe Minimum Cooking Temperatures
Meat and Poultry Temperature Guide Food Network
Internal Temperature of Chicken and Turkey How To Cook Perfect Chicken...
Do stuffed meats take the same amount of time to cook as regular pieces of meat? I have a thermometer.
Ok so stuffed meats and rolled meats take longer roasting time as they have more layers to penetrate. Cook them to 'well done' and just be careful about checking the temperature in a couple of different places.
Feb 14, 2013 • Home
3helpful
2answers
How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
Hi karin 1967...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
1helpful
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
Sep 18, 2011 • Grilling
Need a owners manual for the 34" propane smoker great outdoors smokey mountain smoker
The truth is that the user manual/instruction for your propane smoker is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the instruction/user manual from them. They might give it to you or direct you to a dealer where you can get the instruction/user manual.
This is the best you can do to get the instruction/user manual you are requesting for. Go to the propane smoker's website, check "Contact Us" and you would see their e-mail and phone number.
Below are some instructions that may help you with your propane smoker;
Set Up the Tank
The first thing to do in using your propane smoker is to connect the propane tank to the smoker. Open its valve by turning it in a clockwise direction. Next, you need to locate the wood chip box. Fill the box with any wood that you prefer, like hickory, mesquite or oak.
The wood chips when lit produce a smoky flavor that is absorbed by the food in the propane smoker. Each type of wood produces its own distinct flavor. Remember to soak the wood chips for at least an hour before using them so that they do not burn quickly. Soaking the wood chips also helps to create more smoke inside the propane smoker.
Fill the Water Box
After filling the wood chip box, you need to fill up the water box of the propane smoker. It is usually located right above the wood chip box. You can fill the water box with water or with sand. You can leave it empty, but it is best filled with water because the evaporation during the cooking process keeps the food from getting dry and tough.
When cooking with a propane smoker, moisture is important. Keep adding water when the level in the box is low. To add more flavor to your food, you can also add spices and seasonings to the water.
Cooking Time
The propane smoker is almost ready. All that is left to do is turn on the smoker and adjust the temperature. Most models have a rotary dial that controls the level of temperature in the smoker. The temperature depends on the type of food that will be cooked.
You should use a higher temperature for thick slices of meat and a lower temperature for thin slices of meat or for vegetables. Once you see smoke coming out of the smoker, it is time to put in your meat or vegetables. Cooking time depends on the kind of food being cooked and the thickness of the meat being smoked.
I hope this helps.
Good luck.
Mar 10, 2011 • Grilling
2answers
Is meat placed in main grill or in attached box
The "offset" box is your firebox. This is where you will put your charcoal. The meat goes in the larger chamber on the grill. This type of cooking is known as indirect cooking where the heat source is not directly under the meat. A grill cooks direct with the heat source coming from charcoal or gas burners located directly under the cook grills. Smoker can really deliver some great tasting food. Be patient and learn the ins and outs of cooking with a smoker. The most important thing is to cook low and slow. try to keep your temps in the cook chamber around 225. I hope this helps.
My Brinkmann Electric Smoke and Grill (Double) is cooking
I hope your turkey turned out OK. I read all of the smoking and grilling forums and it seemed to be a very common occurrence yesterday that turkeys cooked in far less time that the grill masters thought they would. Could be that most birds are pre-brined and the additional moisture causes the birds to cook faster. Could be that they are leaner than in the past and the fat renders sooner, causing internal temp to rise faster.
I would let it cook and just check the internal meat temperature at regular intervals starting about 15 minutes per pound.
At what temperature was your smoker running during your cook?
Pat
Top Masterbuilt Grilling Experts
Paul Carew
john h
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
