Question about Acer TravelMate 5720-6462 Notebook
I need to know how to set tabulations - Acer TravelMate 5720-6462 Notebook
  • jeelinda Jul 03, 2009
    Thank you anyway, but it wasn't what I was looking for :)
How do I multiply numbers?
Clear the LCD screen to zero
To multiply numbers, enter the first number by typing the number key pad; press the "X" key and enter the next number; to tabulate those two numbers, press the "=" key
For example, if you want to multiply the two numbers 125 by 425, the expression pressed on the calculator would be 125 X 425 =
Feb 28, 2015 | Canon P23-DHV 12-Digit Two-Color Printing...
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 15, 2014 | Swintec 7040 Typewriter
Guitar serial numbers
That is a 2013, but Schecter does not code any model information into their serial numbers--just internal tracking and tabulation. Are you looking for the model or something?
Jan 29, 2014 | Schecter Music
Epson t30 reset
For every one who say resetter Epson T11, Epson T30, Epson T33, Epson T50 and Epson T60, now resetter for these epson printers getable for download here. All of the software not creation software beause the software has roughened by OrTHoTaMiNe. All software resetter functions exclusive to set ruin ink tabulator.
The Resetter Epson T11, this software make also for epson T10. Resetter Epson T30, there two variant software resetter, One of the software product on Epson T33. There are triplet version of resetter epson T50 and Resetter Epson T60 exclusive available one type.
Jul 28, 2012 | EPSON Stylus Office T30 Series
Maytag pav2300aww wont spin
Does it agitate for the wash cycle?
When you get to the spin cycle, is the motor running and 3 pulleys underneath turning, and the tub is not turning?
If so, I had this issue with this model. The brake would not release, and I had to "persuade" it. Also, I had to set the plastic cam correctly on the bottom of the unit to that is would engage and release the brake at the proper points.
Did not need a bearing kit, just had adjust a few things that got knocked around by the movers. Only took me 6 frustrating hours. Hopefully take you less than 1. BEWARE the 200# force for the spring!
Cost $0. Mental anguish = still tabulating.
Jul 13, 2012 | Maytag PAV2300 Top Load Washer
What ribbon -- item #/type -- do I need for a VTG MANUAL BROTHER PRESTIGE 688 TABULATOR TYPEWRITER?
My best guess is a general ribbon T5. At worst you will have to wrap it on your spools.
DickyO
Apr 13, 2011 | Brother Office Equipment & Supplies
No power response, cable and outlet are good
hi there,
have you seen or heard the fan moving,if that so it may be power supply,unsle you have a tester
to measure the output supply from power supply. try to open the cover of your cpu on side corner there are two lock in bolt,loosening this and slide pull backward to open,on figure as sample the location of quick lock bolt.be45915.gif
then inside your cpu,you can see power supply
there is a specification tabulated on side of pwer supply.on figures you can see.on the arrow pointing power supply. 495dadf.jpg on your cpu you can read the specification
of your power supply take note on this.when you buy new power supply just let them know,mostly
the capacity they will ask you e.g. 450 watts.have a nice day,don't forget to rate me.
ps
removing power on figure you can see cable from power supply going to mother board disconnect them from terminals such as hardisk,cd room.floopy,motherboard,and the sccrew on the backside of cpu.
Apr 28, 2009 | Acer Aspire E360 PC Desktop
I was tryin to program message. Somehow i prograamed something else. Now when i ring stuff in to dept it wont put decimal in right spot. if i ring in$3 in rings in at $300. HELP
Hi.
You may have changed tabulation.
Can you tell me what brand and model you have? Also, does it show the wrong decimal places all the time on the display, even when it is sitting on zero between sales?
Mark
Jan 27, 2009 | Casio Parts Cash Register PC Desktop
Acer TravelMate 5720-6462 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
