Front wheel bearing is pressed into hub and has retaining clip on rear and then cv axle shaft comes through center and has a nut and keeper pin. Rule of thumb is to replace both front wheel bearings at same time. raise front of vehicle place on jackstands for safety remove front wheels remove brake calipers remove front rotors and cv axles remove steering hub assy from lower ball joint,tie rod end and struts take hub to shop and have bearing pressed out have new bearings pressed in reassemble front wheels in reverse order of disassembly.
SOURCE: replace font wheel bearing
What exactly is your problem? If you want help you need to give the chassis number and the engine number as well so that I can be specific and give you the right instruction. Cheers
