Question about Dell 948 All-In-One InkJet Printer
Dell 948 printer. Black(2 inch) Vertical lines when I print
For example, I can print an email with no problem, but when I try to copy a document on the printer I get large black vertical lines on the left side of my paper. I cannot seem to get anyone at Dell to advise me on this. I hate to pay a fee only to realize that I need to get a new printer!!
    President:
  • 2,306 Answers
You need to check the glass for any white-out or other smears that don't belong, if the glass is clean then the scan assembly has elements that are burned out which will cause dark streaks.
Posted on Jun 30, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
My Dell 948 printer produces a thick black line on documents
Leave the cover up and run a 'copy.' Look closely at the fluorescent scanner light and note if it seems equally bright from end to end.
If it does, the photo-assembly that acts as an image receiver is probably sick.
If it is, with the labor cost and potential non-availability of parts, you might be better off replacing it unless still under warranty.
Jul 02, 2010 | Dell 948 All-In-One InkJet Printer
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Dell 948 All-In-One InkJet Printer Logo
254 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
