Question about Nokia 6680 Cellular Phone
Nokia 6680 system error (-1)
Last night i had installed some games in my nokia 6680,after installing i played them untill the battery get empty,after this i restarted the phone and appeared the info 'system error (-1)' and the phone dont work.what do i do to solve this problem?
  • 4,102 Answers
Re: nokia 6680 system error (-1)
You will need to get the phone reset and have the software loaded back onto it some times you can get the flash lead and the programme to do this but it is hard to come buy and you cant buy it from shop or net but it is out their alternatively take the phone to repair shop and they will do this for you for a small fee it is probably that one of the games was corrupt or had virus on it hope this is some help.....................................
Posted on Nov 15, 2007
0 characters
3 Points
Im unable to connect my nokia n70 to pc via cable aithough i had nokia pc suit.when im connecting those cable to nokia 6680 its workking.wt should i do plz help me
Nokia PC Suit software varies in unit models. If you had installed pc suit for nokia 6680 then you need also to install the pc suit for your nokia N70 phone. Use the support cd to install the software.
Hope this could help.
Mar 26, 2010 | Nokia N70 Cellular Phone
I have a Sciphone i68+ I wa installing java games one game I was installing said corrupt file do you ant to delete I deleted that file next thing I know I can't install any games,I tried ti re-install...
From the way you described your problem it seems that your jar reader on your phone has been deleted. You can try update phone software. It re-installs Jar reader. If it does not then I'll provide you with a link from where you can re-install jar reader on phone through pc.
Mar 14, 2010 | Dual Electronics CECT P168 Cellular Phone
In my nokia 6680,pop-up message says that "system error" when my camera video is used both the front and the back camera using my memory card..How do I fix it??
Try the following steps.
1) remove the memory card
2) format the memory card using a card reader on a pc
3) format/reset the phone to factory settings by pressing *#7370# or *#7780#
4) replace the memory card
5) try using the phone
Aug 29, 2009 | Nokia 6680 Cellular Phone
N73 Error certificate error contact application supplier
best solution is update your phone or we can say re install your phone's operating system .. jus follow the link
Mar 24, 2009 | Nokia N73 Cellular Phone
Tomtom on nokia 6680
open nokia failed
-when i swich on they wrote phone register failed
Aug 26, 2008 | Nokia 6680 Cellular Phone
How to unlock my 6680?
try this one
remove your sim card and memory card then press * button,3 button,call button then power on switch for about 10 seconds, then wait untill it reboot......
Jul 21, 2008 | Nokia 6680 Cellular Phone
General: Memory full. Close some applications and try again
Do a Full phone formatting on your 6600! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card. Remove MMC
3. Switch-off your 6680 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory setting.
All apps. installed & not of the phones' default will be lost. If you did a backup on your MMC, you can restore it back to the C drive again.
Jan 11, 2008 | Nokia 6680 Cellular Phone
File is unprotected
get a mmc and install a better mp3 player for your 6680
Dec 15, 2007 | Nokia 6680 Cellular Phone
Nokia 6680 Cellular Phone Logo
268 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
