Question about Kenmore Dryers
Kenmore dryer turns on and operates without heat?
  • 1,000 Answers
Is this an electic dryer? If so, the heating elements run on 220 volts and the dryer motor runs on 110. Check your fuse panel and make sure the fuses have not blown. Then check the outlet at the dryer and make certain you have 220 volts at the receptical.
If that checks out OK, you may have to check the circuit to the heating coils in the back as well as the coils them selves. There are also heat sensors located near the coils that will prevent them from coming on if it get too hot or the sensor is bad.
You can go to the Sears parts web site and get the parts diagram using your dryer diagram. There is an electrical schematic on the back of the dryer that will help you track down the circuit.
Good luck, let me know.
Regards,
Posted on Jun 30, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Why is there no heat and no timer operation?
Whirlpool & Kenmore Dryer Repair - How To Diagnose No ...
? 9:01
www.youtube.com/watch?v=JfXBiZOiC2Q
Nov 3, 2011 - Uploaded by canyonman1963 Whirlpool & Kenmore Dryer Repair - How To Diagnose No Heat - High Temp Fuse 279816 OR 279769 Test. canyonman1963.
Aug 19, 2015 | Whirlpool Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
My kenmore 90 dryer will stop. It is like it
The operating thermostat has most likely failed. When the dryer heats up, it gets too hot and the high limit thermostat turns it off. When the machine cools down, it will start, again.
Apr 17, 2010 | Kenmore 64742 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
DRYER DOES NOT DRY BUT CONTINUOUSLY RUN
Run the dryer for a minute, then open the door and check for heat. If there is heat, the element is ok. If so, you've got a venting issue. If there is a restriction in the vent you won't be able to get as much air out, therefore you won't be able to get as much of the moisture trapped in the air out. The auto dry settings on some dryers require the operating thermostat to open to advance the timer. If there is a venting issue it may cause the dryer to cycle with the hi-limit thermostat instead. Of course, it should not affect the timed dry cycle. so if it won't advance there either you may have another issue. Try taking the vent off the back of the dryer and allow it to vent into the room. This may take care of both of your issues if the restriction is in the home venting, then you would need to sweep the home vent. It's also possible that the restriction is in the dryer blower housing. Without the vent hooked up, turn the dryer on and feel where the vent leaves the dryer. You should have a fairly strong movement of air, if not you'll need to disassemble the dryer and remove the restriction.
Jul 21, 2008 | Kenmore Dryers
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
