Question about Kenmore 71121 Air Conditioner
Power cord replaced, was melted. Kenmore a/c # 580.7112100
The person that replaced the power cord removed the old cord from the unit and does not remember which termnal on the cap the second power lead connects to. The cap has three term's marked: fan, C and Herm.
Its a 6/45uF 270vac cap.
I got stuck trying to repair this thing, and any help would be great.
    New Friend:
    Problem Solver:
  • 9 Answers
Hope this helps
Power cord replaced, was melted.  Kenmore a/c # 58 - 8_19_2015_4_43_21_pm.jpg8_19_2015_4_43_23_pm.jpg
Posted on Aug 19, 2015
What might causeI my electric mower to slow down and speed up and the electric cord connection has overheated at the mower connection?
there is approximately one OME of resistance per foot of power cord. the power cord must be sized according to the amps drawn. if the cord is undersized the motor will not get enough power. the results are a hot cord and probably a hot plug. a loos plug will also over heat, you may need to replace the outlet in the wall as well, get a 12 AWG cord if you are using a 100 foot cord. I personally would never use a 14 AWG if I had a choose, but if the cord was 25 feet or less that would probably be ok. if you are still using the old cord or if the wall outlet is damaged this could cause the ossolating current.
Jul 27, 2014 | Black and Decker USA MM-875 19" Mower...
Replace dryer cord
There should be a cover where the cable goes into. Look at your old dryer - notice where the red, black, white and green cables go to - they should be marked. Compare those to your new dryer. With the power cord unplugged from the wall, remove the cord from the old dryer and install on the new one. The cord should have terminals already installed - you will need a socket to remove the nut holdng the terminals down.
If the power cord is really old and the insulation cracks when you bend the cord, replace the cord.
Dec 16, 2013 | Kenmore 700 6972 Dryer
Frigidaire FRA 155MT1 melted the extension cord and surge protector
You must use a heavy duty power cord with this unit as it draws alot of amerage. Most regular extension cords csnnot handle the amperage and overheat or melt.
Jul 07, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
I have a model # faa065p7a A/C The power cord burned out with some sparks by the test and reset part. Called frigidaire and they said you could not replace the power cord and had to buy a new unit. This...
Hello, i have replaced cords on many window units so yes you can replace the cord. I believe if you go to a online appiliance website they will have the cord you need. I have found this website online with frigidaire parts http://www.repairclinic.com/Shop-For-Parts?s=t-faa065P7a-==
Apr 24, 2011 | Frigidaire FAC124 wall/Window Air...
Kenmore he3: model 110.8708, breaker trips, one side of the 220 line gets hot, and is vibrating while dryer is running.
This may not be tour only but I would inspect the junction block on back of unit where power cord is wired on .sometimes these terminals work loose and start arcing melting the junction then causing a short. UNPLUG UNIT BEFORE INSPECTING. you will have to remove a small inspection cover to see this block, Hope this gets you in the right direction
Aug 13, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
Acer 5050 laptop no power
I have the same thought.
But please check the new power adaptor has the same output voltage as the old one.
If same the power supply unit needs to be changed on the laptop.
All the best!
Sep 02, 2009 | Acer Aspire 5050-3242 Notebook
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
My dehumidifier is dead
WIZ huh? NAGEV says:
check the plug!??? - DUH! I also love ...
5) Remove and test the overflow cutoff switch.
6) Remove the humidistat and check it. Replace it if necessary.
7) If the unit still doesn't work, call an appliance repair person!!!
I guess he's only helping the repair person! Who would pay for this kind of advise? The layperson needs details not big words!
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Kenmore 71121 Air Conditioner Logo
184 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
