How to reset the airbag light? I recently fixed my steering wheel with an airbag in it and the airbag light won't turn off.
always use care when dealing with an air bag,, remove the neg battery terminal,, then the positive, wait 10 minutes for the system to reset , the trick here is hooking it back up, before you do that ,, check all the connections again , make sure they are all tight and aligned,, if so,, Hook up the Positive cable first ,, then the neg one , the light should have cleared, if by chance it doesn't,, your going to have to go to someplace with a OBD code checker,, Lots of places do this for free, so shop around,, and have them clear the code, if it shows up after that , something in the system is wrong, and you'll need to check that before proceeding
