Question about Lexmark Optra M412 Laser Printer
Lexmark Optra M412 pritner find IP address
Lexmark Optra M412 pritner how do I find the IP address
    Genius:
  • 1,018 Answers
Have you printed out the printer's Menu Settings?
Posted on Jun 30, 2009
How do i change the ip address of my printer ..i printed out the menu page and it list an old ip address that i can no longer access
From the operator panel saying "ready". Scroll through the menus to "Network Menu", then scroll to "Standard Network", then to "STD Net Setup", then "TCP/IP", then "Set IP Address". Once you make the desired changes (move through octets using "select" changing numbers using "menu"), make sure to save by pressing the select button until it says "saved".
Nov 14, 2013 | Lexmark Optra T614 Laser Printer
How do I release the ip address
http://www.lexmark.com/publications/pdfs/optras/enUser.pdf
Changing the Network Buffer setting automatically resets the printer.
see page 128
Sep 13, 2013 | Lexmark Optra S 1625 Laser Printer
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
We have an Optra M412 that has a 921 Service fuser error. We don't know where to find the fuser
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
You can find the fuser at the back of the printer, remove the cover and there it is. It holds in two screws and a power connection. If the printer is out of warranty, your next option is to change the fuser which costs around $200, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Sep 19, 2009 | Lexmark Optra M412 Laser Printer
Squeeks even after oiling
Sometimes the squeaks come from the drum inside the cartridge. If you remove the cartridge and power on and don't hear the squeaks, it's in the cartridge and not the printer...
Sep 15, 2009 | Lexmark Optra M412 Laser Printer
Lexmark Optra M412
error 939 means --
RIP Communications Lost
Controller EngineCommunications Lost
The controller board and the engine board cannot
communicate with one another.
Solution --
POR several times
Check each board
for secure ground.
Replace the assys
in the following
order
1. Controller Bd
2. Engine Board
3. Intterconnect
  Board
Dec 12, 2008 | Lexmark Optra M412 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark Optra M412 Laser Printer Logo
229 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
