Question about Nokia 6630 Cellular Phone
Nokia 6630 Memory Problem
I've just purchased a Dual Voltage 1GB Kingston MMC card for my Nokia 6630 only to be dissapointed when trying to copy files over to the phone. I use the phone to play MP3 files and when I try and copy an mp3 file to the phone using the Nokia software I get the error 'Operation could not be completed' However when using the same method to copy to the phones internal memory this error does not occur.
I've tried the usual formatting the memory, turning off and on the phone, PC etc but to no avail. I had heard that there may be issues with the firmware version of the phone which may be causing issues, has anyone else had a similar problem. I'm using the firmware version 6.03.08 13-02-06 RM-1 which I guess is fairly old, could this likely be my problem?
  • Anonymous Nov 17, 2007
    my name is kamal iam using a 6630 nokia when i have been talking some one if in between call i want to know my account balance when i dial the number to know my account balance i unable to know because my has switched off. that is the problem
  • 133 Answers
Why don't you try copying mp3 files to the MMC using a card reader. that would tell you whether your phone update is required or not cause if it works well with the card reader then you could blame the phone. Sometimes trying to update the phone software through the net may cause the phone to crash and that would be even worse isn't it. so be aware tc
Posted on Nov 16, 2007
  • 97 Answers
Beware of updating your firmware if your phone is on Orange. The newer versions of the Orange firmware have an utterly appalling "homescreen" that you can't remove. You can't even go back to the old version. :( It has so many bugs it's unreal, and just to open a received text message takes 6 clicks instead of one. It also crops your wallpaper and makes it blurry. It really reduces the usability and functionality of the phone.
I'd go for the card reader option to load the music onto your phone. It's likely to give faster transfers, too.
Posted on Nov 30, 2007
Hi! Friends i have kingston 1Gb meamory when i inserted it to my nokia 7610 it shows meamory card corrupted what will i do .Plz do hurry
First try to put the memory card to a card reader and if you found that the memory card is reading by you pc.The problem is from the phone so the best way to solve this problem is to contact mobile repairing shop.The mmc Ic might damage.Good luck
Mar 15, 2012 | Nokia Cell Phones
When i send video files via bluetooth from other mobiles to my nokia 6300, the message displays on the screen " file sending failed".Audio files received successfully but video files not. there...
Generally video files are bigger in memory than audio files.So firstly you check the memory status of Phone memory not for the mmc memory.And Check that the memory Card which you are using is less than 1GB Coz more than 1GB mmc is not supported in this model.Even if the mmc has enough space of memory however the size of the mmc is more than 1GB we cannot do this thing sometimes.So try to do what if not.
Apr 07, 2011 | Nokia 6300 Cellular Phone
I forgot password for Kingston 1GB memory card
1.Insert card into your phone but don't access it through phone. 2.Run FExplorer and Open the path C:\system. 3.You will find a file called mmcstore ,rename the file mmcstore.txt 4.Copy that file(mmcstore.txt) to your pc and open that file in notepad. 5.You will find your password in that file.
You can find the FExplorer from the internet..
Dec 28, 2010 | Kingston 1GB Secure Digital Memory Card
I need to unlock my memory card because i forgot my password
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Feb 18, 2009 | Nokia 6230
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
How to remove write protected memory card
micro sd 1gb card write procted problem
Sep 13, 2008 | Nokia N95 Cellular Phone
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Unlock 1 GB micro sd memory card of Kingston Made
I hav a kingston 1gb micro sd card i have forgotten password.plz. help how to unlock the card?
Jun 29, 2008 | Nokia 6300 Cellular Phone
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
MMc Mobile Memory card
try by restoring ur handset and formating ur memory card once...
Oct 30, 2007 | Nokia 6630 Cellular Phone
Nokia 6630 Cellular Phone Logo
226 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
