Question about Acer Aspire 5100 Notebook
Battery not charging
My battery went low on charge and as expected, the laptop hibernated. i stayed for almost a week without using the machine, and didnt recharge. when i tried to recharge later, the battery LED kept on blinking. 7hrs later, the machine still couldnt start and theh blinking LED was still there.
  • mateiutzz Nov 09, 2007
    i have the same problem only i have used my laptop until the battery got low and five minutes later itryed to charge the battery and i got the blinking led and the battery remained at 4% my laptop has 4months and i used the batery only 5 or 6 times what can i do?
    Sergeant:
  • 324 Answers
It's only a guess, but sounds like you will need a new battery. The blinking LED is common with a bad battery.
Ron-
Posted on Nov 09, 2007
Acer aspire one D255 will not charge
You don't have a real serious problem. Just use the Power Cord. Now if the Power Cord does not work, that's a real problem. If your power cord is good and you can use your laptop with it, then the problem is your battery is bad if it will not take a charge. It's time for you to buy a new battery.
Apr 09, 2012 | Acer Aspire One D255-2670
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
Sir my notebooks battery time is of hour hour i want to know that why is its battery time too low
do you constanly sit with the machine on the charger. if so you will have drained the battery. the only thing you can really do if this is the case is keep the charger unplugged from the laptop as much as you can. and as long as you havent took the battery too far down it will start rebuilding its charge time, however dont expect it to happen all of a sudden you will have to rebuild it over a period of a week or so. then in future stay off the charger untill your battery is very low and then charge and unplug the charger once charge so you dont do this again. if your wanting to be on a charger all the time to save the hassel of reaching for the charger all the time. you may want to consider buying a second battery and have one for when you want to be on charger for a long time so you still have a good one for if you want to take your laptop out etc.
HOPE THIS HELPS yourself and others
Feb 06, 2011 | Compaq Presario Notebook
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
My acer mininotebooks goes on hibernating
check to see if your power cable is bad. if it went bad your computer would go to hibernate to save energy, then shut down all together. see if when you plug in your power cable if your computer shows that its charging. if it does maybe its a bad battery.
Jul 13, 2009 | Acer Aspire 5100-5022 Notebook
Lenovo 3000 N200 battery wont charge
no it might not be a battorey problem it could be a software problem,
Sep 11, 2008 | Lenovo Computers & Internet
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Laptop in Hibernation
from your explanation, your battery is low. you need to charge the battery.
Feb 19, 2008 | Acer Aspire 1642ZWLMi Notebook
Acer Aspire 5100 Notebook Logo
253 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
