Question about HP LaserJet 2420 Printer
When I try to print on my HP 2420 I get a box that says print
When I try to print onmy HP 2420 I get a box that says print error. Nothing prints. The printer data light comes on, the lcd says data received but it just sits there. I uninstalled the driver and re installed and it worked for a couple print jobs then it happens again. If I uninstall the driver and re install it will work but this error comes back. I get random PCL XL errors too.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Posted on Sep 09, 2009
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
Hello....i have HP LaserJet printer 2420. when I print it gives me 52.00 error and not printing at all
52.00 error is not good.
If you tried powering off and on and that didn't work, a tech is going to have to look at it.
Problem could be the laser/scanner or the engine control board(ECU)
May 26, 2011 | HP LaserJet 2420 Printer
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
My hp leser jet 2420 printer shows me an error Error 49.2FD9 what is the solution
look here:
and this:
Printed, now not printing nothing changed...
Try shutting down your computer and restart Make sure the printer is on before restarting the system
Have you cancelled the print que?
May 04, 2009 | HP LaserJet 2420 Printer
HP LaserJet 2420 printing problem
Hi all of you
  • try use another data cable.
  • If the printer work proper before do system restore.
Hope this fix your problem,
Thanks
Hamedo
Nov 20, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Problem
Go into your print setting and check the box the has 'print on both sides'. It can easily done if you installed the HP toolbox software.
Apr 29, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
424 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
