Question about Britax Renaissance Si - Prague
How do I re-attach Britax Renaissance straps after washing?
I have had to remove the covers (and therefore had to remove all straps)on my Britax Rennaisance car seat so that I could wash it. I can't remember how the chest harness attached at the back of the seat.There are two straps for each shoulder,through the chest pads, which go into only one buckle/loop at the back. How do they attach as I can not pull the straps taught until they are correctly attached?
  • hlm83 May 11, 2010
    Hi, I have exactly the same problem, I wondered if you had managed to get the straps back on, thanks
busboy2
  • 50 Answers
SOURCE: Evenflo Discovery 5- Pink and green
you need to take the seat to the dealer for safty reasons
Posted on Mar 31, 2008
SOURCE: Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Posted on Sep 27, 2008
SOURCE: Maxi Cosi Priori Shoulder strap folded and caught fast!!
Oh yes I have been there!
I am afraid it took me 2 days of brute force. You'll break before the clip does!
I recall using pliers..
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: harness on seat
I DID THE SAME THING. BUT DO NOT FEAR I FOUND A LINK YOU COULD USE. IT TAKES YOU TO THE WHOLE MANUAL. I HOPE THIS HELPED.
Posted on Jan 03, 2009
SOURCE: britax eclipse
Try Britax.co.uk, they have all the user guides and instructions available for free download. i had the same problem as i washed the seat covers and then couldn't remember how to put the harness back. Hope that Helps.
Posted on Feb 09, 2009
Britax renaissance, do you have to use the belt tensioner or is this just an option as it is ruining my car seat an is nearly impossible to click into place?
Yes, it must be used to properly protect your child. In the UK, contact Britax at:
Customer Service Helpline
Telephone: 01264 386034
Email: helpline@customer-services.britax.co.uk
http://www.britax.co.uk/
Apr 09, 2013 | Baby Gear
Need an instruction manual for britax renaissance car seat
You can find the manual for the Britax Renaissance BB0-545-00 car seat here: http://babycare.manualsonline.com/manuals/mfg/britax/bb054500.html
Aug 11, 2012 | Baby Gear
I have a Britax Renaissance car seat . How do I remove the base unit.
Hi
Normally it's not reccomandable to remove the base ... It's build to last forever and keep the seat sturdy in it's place. This construction gives you the option to change the position into 5 different angles for sitting, resting and sleeping. Just when you want to install the seat or put it into it's "sleeping position" just lift the recline handle under the seat shell and pull it. This way you'll have more space to get the seat-belts through.
http://images.owneriq.net/download/images/7/73cb1008-15f7-452b-8191-2a676308c9fb-000001.png
Hope this answers your question.
Kind regards
Apr 22, 2011 | Britax Renaissance Si - Milan
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
Britax Renaissance Manual Required
i will see if i have one,jollygreenplumbingmachine.co.uk.
e mail me and if i have i will email it back toyou
Jan 21, 2010 | Britax Renaissance Si - Paris
How do you remove the covers of the britax renaissance Si? I really need to wash them. I cant see how the cover comes off.
It is very fiddly and difficult to put back together again.
If you have lost instructions these can be obtained by sending e-mail to Britax via their website
Jul 19, 2009 | Britax Advantage
Lost my Instructions for a Britax Asis Car seat
First attach the long belts to the bottom of the chair. Then feed them through the seat cover and replace the cover. Feed the belts through the back of the chair (through the required shoulder height) and attach to the metal harness at the back of the chair. The folded over edge goes on first, so make sure you put the right belt on the right side! Finally, feed the padded shoulder straps through the same hole as the long belts at the to of the chair and that's it!
Any more problems, drop me a line
Apr 11, 2009 | Baby Gear
A manual for britax freeeway wanted
Not really a solution, as I can't help with putting it back together, BUT the Freeway was retired in 2001. That means that any of them still out there are now well past the 6 year expiration date, and therefore, no longer safe to use. I know car seats are not cheap, but please destroy these out of date seats and put your little sweethearts in non-expired, safer seats.
Car seats expire not only because the technology changes, but also because after a few years, the plastic, like any other material, begins to degrade and weaken even if it looks fine. There's a great video here to help show this.
Jan 07, 2009 | Britax Eclipse Si - Paris Convertible Car...
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax eclipse
Jul 16, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax Renaissance Si - Prague Logo
218 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
