Hi. I researched your motherboard, and AZUM is right you CAN easily add up to 4 GB of memory on your board. The spec sheet says you need the 184 pin type, and it can run up to DDR 400 type memory. Other DDR speeds will run on it, but will slow your performance. At the cost of memory these days, Isuggest you go with as much as you can. The max memory size your board can handle is 1 GB in each stick I believe, since there are 4 memory slots on your board, and the max your board can have is 4 GB.
You do not need to change power supply and you can easily add 2 GB of Ram ... no problem nothing to worry
