Question about Acer Aspire 5315 Notebook
Jumpy cursor on Acer Aspire 5315-2122
Cursor jumps erratically while typing/ Also may refuse to type individual letters and highlights then changes text.
    President:
  • 3,278 Answers
Would advise you to download, install and run anti-spyware and anti-malware software, such as SpyBot and MalwareBytes. Good luck.
Posted on Jun 30, 2009
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
Nov 10, 2009 | Acer Aspire 5315 Notebook
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Hyper senitive & erratic mouse
reinstall the driver for the mouse and see if that fixes it.... also you can try going to control panel----mouse and the changing the settings... you may have to experiment abit to get it the way you want it.
Robert
Please take a moment to rate this solution... thanks
May 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Jumping cursor whilst typing on an acer aspire 5315
Is the touchpad active?
It is common that users accidently touches the touchpad while writing and this causes the cursor to "jump"...
Another possibility is that the "TAB" key is jammed...
May 05, 2009 | Computers & Internet
Cursor continually jumps all over when trying to type
Touch pad mouse.
This unit has a "seamless touchpad with four-way integrated scroll button".
Yours is probably faulty, causing the cursor to be random.
Try disabling it and connecting a USB mouse.
Apr 26, 2009 | Acer Aspire 5315 Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
Cannot access C: drive & typing is erratic
download spybot from www.spybot.org, install it, download updates, scan (takes 20 minutes or so), click 'fix selected problems', click the button that says immunize, then Immunize.
reboot
should be fixed
hope this helps
chris
Dec 15, 2008 | Acer Aspire 5720-4230 Notebook
Skipping cursor problems
i was trying to assit my lacousin with her laptop "issues" and could not figure out how to stop the cursor from skipping around. when you start typing on her laptop the cursor has been known to:
move randomly while you're typing
highlights text and deletes it
jump all over the page
After doing many google searches, I was unsuccessful in finding a solution so I thought I'd post here. I have tried to make her touch pad less sensitive but nothing seems to work.
Thanks for touching basis with me for clarification...hopes this helps!
Oct 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5315 Notebook Logo
369 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
