Question about Troy-Bilt 24A-06MM066 - CSV060 24" 173cc Chipper Shredder Vacuum
I have a Troy-Bilt 24A-06MM066 CSV060 shredder/chipper combo that won't start
It won't start unless you pour gas into carb hole and it will run for about ten seconds and then cut off, anybody know whats going on?
  • Troy-Bilt Master
  • 901 Answers
Your carb is gunky up from bad gas most likely.
Anytime an engine will run for a bit after putting gas into the carb, you are pretty well assured that it's the carb.
Remove and clean the carb paying special attention that all the little orifices are open by spraying carb cleaner into them.
Posted on Dec 07, 2017
  • obsteiner Dec 07, 2017
    Your carb is gunked up from bad gas most likely.
  • 3 Answers
SOURCE: need set of 4 impeller vanes for Troybilt chipper model 47261
You can get the impeller parts at:
http://www.thefind.com/garden/browse-troy-bilt-chipper-vac-parts
Good luck,.,
I just purchased a used 47261 yesterday for $200 .. It is like new, but I may need a new bag from this site and I will need to find a manual somewhere.
MrBill
Posted on Jun 25, 2009
mowerman1857
  • 389 Answers
SOURCE: Troy-bilt Model 47279
I really hate to be the "bearer of bad tidings" but Troy Bilt, as a company, in no longer in business, MTD bought out the name and design rights for a lot of their tools but they are not manufacturing or stocking any parts for the older GardenWay/ Troy-Bilt machinees. My best suggestion would be tostart looking for a good used one or one with a blown engine, broken frame or whatever, buy it and canibalize it for spare parts
Posted on Sep 16, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt for a Troy-Bilt 47024
Troy Bilt Part Number 1762636
Posted on Sep 29, 2009
SOURCE: Where can I get a leaf tamper for my 47321 Troy
THE CHIIPER PRODUCT IN NOW OWNED BY MURRAY. PART NUMBER FOR LEAF TAMPER IS 1763008. ORDER FROM ANY POWER EQUIPMENT DEALER THAT ORDERS MURRAY PARTS.
Posted on Mar 31, 2010
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
Briggs & Stratton 650 (Model 120000) lawnmower engine on a Troy-Bilt CSV060 lawn vacuum/chipper/shredder. Was stored for several months with no oil/gas. Recently got it out and filled oil/gas. Would...
you are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
Jul 08, 2017 | Troy-Bilt Heavy Machinery
Gets no gas will start and run if you keep spraying starter fluid in it. Gas tank emptied & refilled line is clear.
take `bowl off carb. claen well and replace. If you didn't completly clean tank and fuel line, do it again spray carb. cleaner direct into carb. and try starting. The cleaner may need to be used several times. good luck. l
Sep 28, 2010 | Troy Bilt Walk Behind...
My troy-bilt chipper vac (4.5)hp engine) will only run a few sec if I pour gas into the engine. it does not seen to be getting any gas. where can I look for the ptoblem? Rich
Look for fuel flow issues, pull the hose off at the carb and see how much volume comes out for how long. if low volume, look upstream. Usually screens get gummed up.
Sep 25, 2010 | Troy-Bilt ChipperShredder
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Troy Bilt Chipper/Vac 47282
There is a blockage in the outlet from the fuel tank, there is a filter in the tank and it is dirty. Try it anyway. Stephen.
Sep 21, 2009 | Troy-Bilt Chipper Shredder
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
May 01, 2009 | Troy Bilt Walk Behind...
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt 24A-06MM066 - CSV060 24" 173cc Chipper Shredder Vacuum Logo
196 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
quennie732
Mike
lnbn1975
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
