Question about Xerox Phaser 8560MFP Laser Printer
Error Code 09,038.46:1529
Xerox printer 8560 has error code 09,038:46:1529 and will not function. Unable to find this code anywhere in the documentation.
    President:
  • 2,072 Answers
One of your ink sticks is stuck and not loading properly. It is not advancing down in the ink loader.
Look for a twisted block, cracked or just stuck not sliding down.
If you need to remove them take a screw, like a dry wall screw and twist it into the block then slide it out or down.
Posted on Jul 01, 2009
Error code 07,015,48:94562
That error signifies the head tilt restraint is out of place. There is a kit that solves this error, the part number is 8560-Z2. http://www.iteminconline.com/itemdesc.asp?ic=8560-Z2&eq=&Tp=
Aug 27, 2014 | Xerox Phaser 8560MFP Laser Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
08,030.46:45203 error code with xerox 8560 printer
Are there obstructions or spilled ink on the Wiper Blade, the Head Tilt Gear drive path, or under the Printhead?
Is the Waste Tray overfilled?
Clean the inside of the printer and retest
Mar 10, 2014 | Xerox Office Equipment & Supplies
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Error Code 07,010.43:15005
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
Apr 01, 2009 | Xerox Phaser 8400DP Thermal Printer
Xerox Phaser 8560MFP Laser Printer Logo
425 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
