Question about Technics SL-PG480A CD Player
My cd-player SL-PG380A is showing no disk some times, I've tryed cleaning . what can be wrong, and what would it take to fix???
  • 400 Answers
Get a new battery first and it may also take lens to be changed ...thank you
Posted on Jun 30, 2009
  • Azum Saeed Jun 30, 2009
    sorry it only need to change the lens of the rom.. thank you
  • 3 Answers
The laser azimuth is worn (the Laser head assembly) do not replace unless you know how to!
The laser beam can damage your eyes if you look directly into it.
CPC uk ltd maybe able to supply you with a replacement, however be prepared for P+P= £50 or so
Posted on Dec 20, 2009
Checking disks and gets ERROR
Trow it out, I can get a good used disc player where i live for $10 to $30 at the most, End they are not hot, It will cost you a lot more then that to have it repaiered,
Nov 25, 2012 | Technics SL-MC6 CD Player
I have not played my cd changer for a year and when I just try to play a cd now the system appears to look for cd but the word error comes up on the display. Just the word error not number. Any ideans...
Hi!
I dont't think that your cd-changer is broken. It may only need some cleaning. One year is time enough for dust to set on optical reader. I suggest to use a cleaning disk, available on every store selling optical media.
Hope it helped,
Bogdan
Sep 23, 2011 | Technics SL-MC70 60-Disc CD Changer
I have a 3-CD player. The system does not recongnize the discs and shows no disc in display. Is it the potentiometer adjustment that is required ? Please suggest.
  • The majority of the time when a disk player shows "no disk" when attempting to play a disk either the disk is formatted wrong for the player or most likely dirty.
  • Just get a lens cleaner and run it through the player two or three times. These lens cleaners are disks with very soft bristles on them that "sweep" the lens clean.
  • The lens is real dirty and needs a good cleaning to be able to read the CD. This is common with all disk players that have not had a cleaning as they should.
  • Be sure to give the cleaning disk a run through once a week.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 01, 2011 | Daewoo Audio Players & Recorders
I have a technicks sl-pg380a audio player and it reads no disk..i tried putting in other disk everything..i took it apart and found out one of the motors wasnt working..the one that spins the disk..how can...
Be careful. The unit will attempt to verify that a disc is present BEFORE it tries to spinb the disk. If the optics are defective, this can happen. First try cleaning the lens using a cotton swab and alcohol. Try to play a clean disc. If it fails to play or read the TOC, then the optics need to be replaced.
Please keep us posted,
Dan
Aug 24, 2010 | Technics Audio Players & Recorders
My cd changer is not recognizing the cd's that are inserted and the screen reads "error". why is that and how can I fix it?
if you have cd disk cleaner try to insert. if not work try to clean manually using cotton badge clean directly to optical lens.
Apr 20, 2010 | Technics SL-MC70 60-Disc CD Changer
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
When i put the disc inside the cd player, the disc run during a time like 5 minutes and after this show a mesage "no disc", but the disc is insede yet. i need i help
Hello my friend, try another disk and if it fails again clean your cd player with a disk cleaner cd either liquid solution or dry. If you don't have disk cleaner try to purchase in any store you have in your area or shop at online in this site: http://www.nextag.com/cd-disk-cleaner/search-html . Further steps in cleaning cd/dvd player surf this iste: http://labnol.blogspot.com/2006/07/how-to-clean-dvd-or-cd-disc.html. And if all of the given steps are not helping then try to contact your supplier or technician in order to check if your player is working properly.
any progress to your problen you may contact me.
Thanks
Jun 16, 2009 | NAD C542 CD Player
No disk
Try cleaning the lens directly by carefully using a cotton swab and alcohol. Update this with your results.
Dan
Mar 25, 2008 | Technics SL-PG350 CD Player
SL-PG380A
I know it's late but i happen to have received the same unit for free, and it had the same problem. The reason for the message is that the laser weakens over time and cannot reach the CD anymore. If you try holding a disc directly above the lens, to the back of the spindle, you will see the motor starting to spin. That means the laser is still working but too weak to reach to the height of the spindle. The solution is simple. Take the drive unit out and remove the three screws on the board at the back of the drive. Carefully lift that board, there is a flex cable connected to it you don't want to break. You will see a little variable resistor with three pins. Measure the single pin against both of the other two. One should read 3.something kOhms, the other 1.something. Mine read 1.35. Using a small screwdriver turn the resistor to the right until the side that read 1.35 reads something around 700 ohms. I left mine at 740 and it works fine. Put the drive back together and load a disc. It should now work again. Don't set it any lower than 400 or you will damage the laser. If it doesn't work with 800-400, the laser is probably damaged and the drive needs to be replaced entirely, which is not worth it.
Mar 25, 2008 | Technics SL-PG480A CD Player
Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Dec 25, 2007 | Technics SL-PD5 5-Disc CD Changer
Technics SL-PG480A CD Player Logo
838 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
