Question about Garden
My 2006 troy-bilt superbronco wont start. There is only a clicking sound that comes from under the seat. Batery is fine and the starter is new.
  • 1,000 Answers
There is a "starter" solenoid that closes when the ignition key is turned to the start position.
Follow the positive (red) battery cable from the battery post to the solenoid. If you have a 12 volt test light or volt meter, check to see if you have 12 volts on the battery side of the solenoid then turn the key to the start position and see if you have 12 volts on the starter side of the solenoid.
I believe you have a starter solenoid that has gone bad.
Good luck, let me know.
Regards,
Posted on Jun 30, 2009
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
Wont trun to start
park brake must be engaged, cutting attachment disengaged, still no clicking sound? Lawn Mower Parts Genuine MTD Parts for Outdoor Power Equipment You will find the correct manual at this link
Apr 13, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Troy-Bilt Garden
I have a riding lawnmower. Troy-Bilt Bronco. It will not start,no noise,Just put a new Battery in.Where is the fuse located?
Sometimes the fuse is located off of the starter it would be an inline fuse like half turn clip or maybe under your seat. Good Luck...
Aug 24, 2011 | Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Brand new, troy-bilt chipper model 4265. put oil in engine filled it with gas and tried to pull the recoil starter. It's locked up. I could lift this unit in the air with the recoil starter.
Sounds defective. Even if you could fix this problem something else is bound to go wrong. Troy-Bilt has a reputation for quality products and I'd suggest, since it's brand new, you get it replaced.
Apr 10, 2010 | Troy-Bilt Chipper Shredder
Troybuilt/bronco wont start
IF YOU HAVE A NEW BATT IT COULD NEED THE VALVE LASH RE SET
Sep 19, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
309 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
