Question about APC Back-UPS CS 500 UPS System
Unit keeps beeping even when unpluged. over load
Unit keeps beeping even when unpluged. over load light is on how do i reset it.
  • 630 Answers
UPSs will beep when unplugged to tell you that the mains is off! Overload should reset if you disconnect both the load and the power.
Posted on Jun 30, 2009
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
Constant beeping
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
Jan 26, 2009 | Whirlpool LHW0050PQ Front Load Washer
Keeps beeping when recharging
It sounds like you need a new battery (this is what the beeping is) even though its only a year old the battery needs replaced!
Please rate my answer and help keep this site FREE!
Thank You!
Dec 28, 2008 | Black & Decker Simple Start Car to Car...
I have an older fridge freezer which has 3 lights in fridge ,1 for if ive left the door open, 1 for i think tempreture and 1 with an s on also a on/off switch.I just purchased this 2nd hand and its great...
What make and model is this unit. It sounds like it could be an error code. Possibly a thermal fuse or something in the defrost cycle. Try unpluging the unit for 15 mins and plug it in again. It will at least reset it and it may run until it hits the defrost cycle again. You are most likely going to require service.
Sgt 48
Jun 02, 2008 | Zanussi Refrigerators
Keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Mar 24, 2008 | Frigidaire FEQ1442ES Electric Dryer
Warsher panel goes wacky......
Sounds like you possibly have a short in the touch panel unit.  Very hard to know for sure, but that is usually the signs we get when one goes out.  The problem is this touch panel is seriously expensive.  Try this, unplug the machine for around 15 minutes.  Sometimes they can hang up.  Unplugging it would cause the computer to sometimes reset itself.  If it does the same thing when plugging it back in, its that touch panel.  You cant always see any burned or scored areas to indicate a bad board.  Good luck and let me know if you need any further help.    Jim
Oct 23, 2007 | Maytag Neptune FAV6800AW Top Load Washer
APC Back-UPS CS 500 UPS System Logo
600 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
