Question about Husqvarna 23 Hp 48" Deck Yard Tractor
I put oil/mix gas in the mower. The mower stopped
I put oil/mix gas in the mower. The mower stopped running as soon as the engine recieved the mixed gas. Now the electric will not turn on to even attempt to start the mower.
rockitman187
  • 2559 Answers
SOURCE: what's the gas/oil ratio for CT 16 tiller
Husqvarna says 50:1
Here is a link to the break down repair manual for future use
I will send a link to the user manual when located.
Please rate this fixya solution
Posted on May 13, 2009
  • 597 Answers
SOURCE: Husqvarna 223l trimmer shuts off
See if air cleaner is plugged or needs changed or cleaned
Posted on Jun 05, 2009
  • 323 Answers
SOURCE: chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: gas is mixing with oil
The float needle and seat in the carb are leaking and need to replaced. Don't run the engine with the gas in the oil. You will fry your engine. Get the carb fixed.
Posted on Jun 24, 2009
dontbother10
  • 2220 Answers
SOURCE: what is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Posted on Oct 30, 2009
What is wrong when oil mix with gas and the riding lawn mower will not start?
Riding mowers are usually straight gas, not mixed. If you accidentally put mixed gas in it the carb, plugs, and engine may be gummmed up. Clean, flush, start with fresh gas, and you should be OK
Mar 08, 2015 | Garden
Engine wont run with wrong fuel mix
drain the fuel and replace with fresh fuel if you cant get it started you might need to replace the spark plug
May 03, 2012 | Briggs & Stratton Garden
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Does the poulan p4tn20sa take a gas/oil mix?
I cannot find any literature on your mower, but I'm guessing it has a 4 stroke Brigg's engine on it. If so, then there is no gas/oil mix requirement. The only engine's where you mix gas and oil are 2 stroke engines, which are not installed on most of today's mowers. There should be a separate place on your mower to put gas and oil in. If so, then you should probably run straight 30 weight oil in it and do not overfill it or you'll ruin your engine. I hope this helps. James.
Jun 26, 2011 | Poulan "" Push Mower
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
What is the mix of oil to gas in a troy bilt self propelled lawn mower 12av566n711?
if it is a 4 cycle engine, do not put oil in gas. if it is a 2 cycle engine, usually a 50/1 ratio works good. depends on brand of oil, so follow directions on oil container for mixing directions.
Apr 17, 2011 | Garden
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Engine ligh is on, Overdrive light blinks on
check if you use e-mix fuel
if that is the case , put a bottle of methylated sprirts in the fuel tank to mix with the water from the e-mix fuel and then after running the fuel out, refill with normal fuel and a quality injector cleaner
May 18, 2017 | 2003 Ford Excursion
I just bought a Weed Eater 22" gas push mower. Do I mix oil with the gas to run, as I do not see an oil input? p.s. I purchased this at a yard sale.
If it has a dipstick or plug to check the oil in the engine you do NOT mix gas and oil.
Use regular unleaded gas only and use 30 weight detergent oil in the engine crankcase if it is low.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Jun 15, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
149 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
