Question about Mitsubishi VS-5075 50" Rear Projection Television
No picture-picture- I just got this TV second hand and the picture blanks out when ever it wants. It comes back on when ever it wants as well, unless I smack the side of the TV. I suspect a loose connection, does anyone know where I can get a schematic for this television, or at least point me to the right board to pull? thanks
  • Mitsubishi Master
  • 8,617 Answers
Re: No picture-picture-
Try resoldering the vertical output IC. If you still need a service manual let me know and I will post a link where you can get one.Just post the model number of your set.
Posted on Mar 25, 2008
0 characters
3 Points
My tv has full picture for about two minutes thengoes blank the green light blinks then comes bak on and repeats the process
You have to reset your tv.
If there is no reset button,then while the tv is on unplug the cord from the wall socket,this shouid reset the tv.Wait about 5 minutes before you turn it back on.
If this doesn't work then,your tv is about to go,unless you have a valid warranty.
Hope this helps.
Nov 26, 2013 | Projection Televisions
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Color Rear Video Projector- KP-61V45
You have already diagnose the problem,the set has a loose conection in the high voltage area or horizontal drive circuits but dont be suprize if you find more loose conections or overheated areas,while you are looking for this loose conection giving you this problem take the time and correct any other questionable spot.If you are familiar with tv service this will give a place to start but if you are not too familiar be safe and call for assistance from a servicer,it should not be expensive.Let us know if youu need more help.
Oct 12, 2006 | Sony KP-61V45 61" Rear Projection...
Won't turn off unless unplugged
Ther eis a stand by function on the Television. If you have the owners manual read about that function. Th ered light stays on because it is programed to come on a t a certain time. Go to menu and find the stand by function.
Aug 17, 2006 | Sony KP-51HW40 51" Rear Projection...
Projection Televisions Logo
95 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
